My oil pan has some really heavy rust. I wish it would just rust through so I could have it replaced before the engine warrnanty expires. Im affraid if I bring it in now they will just give it a light sanding and paint it. Sorry thats just not good enough. Anybody else have this problem?
I heard that there is a TSB about that at Ford. Something about a special paint that they can apply to the pan. Don't quote me on it, though, as I am unsure. You might be able to get that done for free before the warrenty expires.
Your engine warranty probably has a $500 deductable. I would just get some POR15 and put that on there over the rust spots. It will never rust there again.
That's what I did. Like liquid enamal when it dries. Very good stuff.
My 2001 has the same problem, Ford here said that they would cover it under the 5 yr/ 100k diesel warranty, but, not until it actually leaks! Now, get this, they told me the pan is $150 or so and the labor is like 13 hours, they said they have to remove the engine! Total bill would be a grand!!!
ya the entire motor has to be removed turned upside down and the special sealent has to dry for a day before the motor can be reinstalled in the truck so avour 2 days to remove 1 day to fix 2 days to put back together it suxs ive done it not fun.
