Lower Radiator Hose Spring?
Old Sep 26, 2005 | 08:03 AM
nzabka's Avatar
nzabka
I changed all the hoses on my 96 F150 (302) last night and was fairly satisfied except for one thing...The new lower radiator hose did not have the spring in it and I was unable to get the old one out without ruining it. I called O'Reilly's where I got the hose (Gates brand) and they said it would probably be fine and that Gates probably changed the design on it so it wouldn't need a spring. ??? So I called the only other parts store open , Advanced, and they basically said the same thing.
Anyone ever run across this? I thinking about just going to Ford and see if they sell one with the spring in it. Or am I fine without it?
Old Sep 26, 2005 | 08:46 AM
MrBSS's Avatar
MrBSS
I've always reused or replaced the springs in the lower radiator hoses, so I can't be sure if you would be fine without it. My understanding is that it prevents the lower hose from collapsing when the water pump is sucking coolant at high speed. I think that a new hose would not be soft enough to collapse, but you might have a problem if its still in service in five years or so. That's probably why the replacement hoses don't bother.
Old Sep 26, 2005 | 02:02 PM
jtmerritt's Avatar
jtmerritt
Don't believe the parts guys about the lower hose not collapsing without the spring. Even if you have to buy a new one from Ford don't go without it. Usually if you can slice the old hose lengthwise you should be able to get at the spring to get it out.
John
Old Sep 26, 2005 | 02:59 PM
rebocardo's Avatar
rebocardo
Get the one with the spring. Logically if Ford could have saved $0.10 by leaving it out of the hose for *600,000+ trucks they would have done it. They do not save money by replacing motors under warranty. A new hose might be alright for a while, but, after the hose is old, hot, and pliable, I would not count on it not needing the spring.
*600,000 trucks per year, figure how much they would save after ten years by dropping the spring.
Old Sep 27, 2005 | 12:57 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
The last time I replaced the lower hose (new had no spring) I installed 3/32" stainless Tig rod that was wrapped into a spring (ends tucked in) into the hose, no problems the last 140,000 miles.
.....=o&o>.....
Old Sep 27, 2005 | 07:55 AM
nzabka's Avatar
nzabka
hmmm...tig rod, eh? Only problem with that is I don't have any of those around and I'd have buy a bundle. I'm assuming they're just as expensive as a new hose from Ford?
I don't know...
I guess I'll just go buy the Motorcraft hose with the spring since I'm in a bad spot for time...
Thank You for the ideas though, they were much appreciated.
Old Sep 30, 2005 | 02:10 PM
"Beemer Nut"
Go by any good weld shop and buy one rod, heck give him a buck, he's happy and you got a cheap fix. Think outside the box.
.....=o&o>.....
Old Oct 19, 2005 | 02:52 AM
Ed's Avatar
Ed
Red face
I agree! Unless you are getting ready to sell it in a month, make sure the lower hose has a spring in it. They help the hose to last longer as well, because the extreme coolant heat will make the hose soft. Many "head scratching" overheating problems can be directly traced to a lower radiator hose that collapses a little, causing slight coolant blockage This usually won't occur until the engine is hot and under a load, in gear. For the minimal cost, always use a spring hose. The icing on the cake is what Rebocardo said. if Ford could save the $$ for every spring in the lower hose, they would have done it, if it was not needed. Ed
Old Oct 19, 2005 | 11:46 AM
MrBSS's Avatar
MrBSS
Apparently it is standard practice to omit the spring in replacement hoses, but you can usually re-use the old spring.
Old Oct 19, 2005 | 12:11 PM
"Beemer Nut"
aAbout a week ago I ran across another members pretty motor photo and the full length of the top hose was flat.
.....=o&o>.....
Old Oct 20, 2005 | 09:47 AM
Sycostang67's Avatar
Sycostang67
I have been told the replacement hoses are stiffer and less likely to collapse. I have had no problems with the ones in my cars yet. When I replaced my radiator in my truck, I noticed the hoses came from Napa Auto, and they both had springs in them.
Jul 26, 2019 08:34 AM
Lambert01
Jul 27, 2017 02:47 PM
eisman
Jan 23, 2017 09:08 AM
Crims
Oct 11, 2016 08:58 AM
more d
6.4L Power Stroke Diesel
Jun 4, 2013 01:54 PM
