I need to repair a plastic windshield washer reservoir that is leaking. Does anybody know the exact material it is constructed from (PVC, polyethylene, etc.)? Any suggestions regarding methods and materials (e.g. JB weld, plastic welding)? Any success stories? Thank you for all responses.
One of my sons crashed and punctured a hole in a plastic gas tank on his dirt bike a few years ago. I looked into plastic welding or buying new, then had a buddy suggest a torch and flat head screwdriver. I heated the screwdriver (continuously) then slowly skimmed plastic to fill the hole. Worked like a charm. Never leaked a gain. Best of all it didn't cost a penny to fix. Just watch not to skim to much from an area. Take your time and it should work fine.
A soldering iron can be used. If you have a pencil type unit sometimes you can find wide tips to put on it. They used to sell a wide tip for soldering guns also. Check with the hobby stores also. The easiest route to go is just to replace the part with a unit from a salvage yard. Sometimes using heat for repair like this can result in a brittle section that will crack again.
I have had good luck with hot glue. There are a lot of different kinds of glue sticks, you can find them online. Get the polyethelene glue sticks and heat the edges of the crack with a soldering iron as you apply the hot glue.
Also, you and make yourself some "welding rods" out of milk jugs, or any other polyethtlene throwaway container. Melt the crack with your soldering iron and feed in you rod. Works.
There's also some other stuff you could use, but it's a bit expensive. But there's a 2 part epoxy that will fix ALL automotive plastic structurally, you just need a bit of 40 grit sandpaper, some mesh tape, and a bondo applicator. You might be able to get it at NAPA. If all the other posted ideas don't work, this stuff will.
