Fuel Sending Unit Issues
Old Sep 25, 2005 | 06:38 PM
btacarlton's Avatar
btacarlton
Exclamation Fuel Sending Unit Issues
Hey Everyone,
I have a 77 F250 Highboy that I am restoring. I bought a 5 gauge set from Dolphin gauges that comes with a sending unit for the fuel gauge. I dropped the tank and realized that the stock sending unit also contains the fuel line. I hooked up the new gauge to the stock sending unit and when the float arm is all the way down the gauge reads just over half full. When the float arm is raised all the way up the gauge reads empty. Obviously the Ohms readings for the gauge and sending unit are different. How can I change the ohms reading so the two are compatible? I would like to use the new sending unit so I know the gauge will be acurate, but I don't want to have to drill a hole in the tank. I was told I could either put resistors in line between the two or use a rheostat to change the resistance reading. Has anyone used either of these methods? If so, what size resistors or rheostat? Any help anyone can give would be greatly appreciated. Thanks in advance.
Bill
Old Sep 25, 2005 | 09:14 PM
LxMan1's Avatar
LxMan1
I don't think that a resistor will help. It sounds like the aftermarket one works the opposite of the stock one as far as resistance goes.
Old Sep 26, 2005 | 06:59 AM
btacarlton's Avatar
btacarlton
Is there any way to change it so the two are compatible?
Old Sep 27, 2005 | 12:02 PM
btacarlton's Avatar
btacarlton
Can anyone help? Thanks.
Bill
Old Sep 27, 2005 | 02:52 PM
Rockershaft's Avatar
Rockershaft
Maybe if you went back to Dolphin they would have a gauge that works on the ford sender, or a sender with a pickup tube for the fords.
Old Sep 27, 2005 | 10:13 PM
Ford_Six's Avatar
Ford_Six
You do have to use an aftermarket sender for the gauge, Ford used their own resistance values for quite a few years. Most of the aftermarket gauge companies use the same resistance, so you may be able to use an autometer sender, I do believe they have one that fits that tank.
Old Oct 4, 2005 | 01:54 PM
btacarlton's Avatar
btacarlton
Finally talked to the place where I bought the gauges and was told that I need to remove the resistor block from my stock sending unit and replace it with the resistor block from the new sending unit. I have to position and weld the new resistor block onto the fuel pick up line on my stock sending unit. Sounds like FUN! Maybe I will put in a tech article when I am done in case anyone else trys this down the road.
IDI-Charlie
31
Aug 20, 2025 10:34 PM
hoss73ford
Aug 11, 2015 10:47 AM
rswhitmore
Mar 20, 2015 10:27 AM
awhtx
Nov 17, 2010 12:53 PM
ChuckT
Jul 27, 2006 11:35 AM
