General Automotive Discussion
Pinto axle...
Old Sep 25, 2005 | 05:30 PM
1970Custom's Avatar
1970Custom
Question Pinto axle...
...What other vehicles used this rear end? Isn't it a 7.5"?
Do any companies offer five lug and disk brakes for it?
Thanks,
Eric
Old Sep 26, 2005 | 01:06 AM
85e150's Avatar
85e150
Might be a 7.
A switch to an 8" would better serve any performance upgrade. Stainless Steel Brakes might make a kit for the 8.
Old Sep 26, 2005 | 11:39 PM
1970Custom's Avatar
1970Custom
One other thing, is this a stout piece? I'm thinking of putting it under my rx7 and want to make sure before I get too far into it.
Old Sep 27, 2005 | 07:03 AM
rebocardo's Avatar
rebocardo
I have seen Mavericks with disc brakes in the back, that might be a better choice. If you are thinking about something narrow for an RX-7 I do not see why you do not use an 80s Ranger axle. Much more support for that including lockers and limited slips.
Old Sep 27, 2005 | 05:33 PM
1970Custom's Avatar
1970Custom
This already has a full spool in it with 3.55 gears. Just wondering about strength as I'm going to be building a high power 1.1 or 1.3.
Old Sep 28, 2005 | 12:52 AM
85e150's Avatar
85e150
I had an 8" open diff in a Mustang with a 289 and manual trans. 3.0 gears and it held up after I broke the 2.79s.
Go here for 8" goodies:
http://www.davidkeetoploaders.com/thirdmembers.htm
scroll down for the 8's
http://www.currieenterprises.com/cestore/8inford.aspx
An 8.8 from a later Ranger or Exploder, if it will fit, might also be considered.
Old Sep 28, 2005 | 01:02 AM
ford390gashog's Avatar
ford390gashog
no i think you need at least a D70 under there and some 4.10 gears. J/K
Old Sep 28, 2005 | 05:41 PM
1970Custom's Avatar
1970Custom
I've read about the 8.8 but they are heavy compaired to the original, everybody I've talked to used the 8.8 on high hp vehicles ie 400+; as I'm only looking for about 250-275. I'll check those sights though. thatnks.
Old Sep 28, 2005 | 10:58 PM
go_racing84's Avatar
go_racing84
If it's related to the 7.5" they used in Mustangs and Thunderbirds in the '90s, it's not that stout at all.
Old Sep 29, 2005 | 06:03 AM
snyiper's Avatar
snyiper
The turbo t-bird rear seemed to hold up well to the power they made. I would also say look at a Maverick Grabber rear. or perhaps a 70s shelby cobra rear (hopped up mustang 2).
Old Sep 29, 2005 | 12:05 PM
rebocardo's Avatar
rebocardo
When I said Ranger/Bronco I meant the 7.5 rear end. It should hold up fine and depending where you live you can buy them from $25 to $100 because, generally, people do not want them. It is probably good for 200 horsepower.
Old Sep 30, 2005 | 05:09 PM
85e150's Avatar
85e150
Turbo T bird should be an 8.8, shouldn't it?
The Maverick and Mustang 2 would be 8" diffs.
Old Oct 1, 2005 | 12:59 PM
FLgargoyle's Avatar
FLgargoyle
I doubt you'd tear it up; Wankel (rotary) engines aren't known for a lot of torque, and you're talking a light car. Of course, the bigger the better!
Old Oct 1, 2005 | 01:15 PM
go_racing84
FLgargoyle makes a point. What kills a differential is shock load from a high-traction launch, or otherwise. As long as you're not running large drag slicks and launching at 9k, a reconditioned 7.5 will probably last for a while.
Old Oct 2, 2005 | 02:57 AM
1970Custom's Avatar
1970Custom
Thanks Jay, I'm going to autoX the car, the tires will be slicks but of the circle track variety on 13" stockers.
egregg57
New Hampshire Chapter
Jul 25, 2012 03:44 PM
Fomoko1
Mar 20, 2007 01:21 AM
erics
Jul 27, 2000 11:48 PM
Eric B
Nov 27, 1999 08:51 PM
