97 F250HD 5.8L Engine Polution ?
Old Sep 25, 2005 | 08:06 AM
JeepNut401's Avatar
JeepNut401
I am new to the site, great source of info. I have a 97 F250HD with a 5.8L auto and the oil pan started to leak and had a exhaust manifold crack. I ended up pulling the engine to replace the pan, two exhaust manifolds, rear seal and freeze plugs. The engine was quite rusty from plowing snow for years. My question is there is a air pump on the motor and exhuast tubes coming from each manifold for polution control. Could I block the back of each of these manifolds and do away with this gear? The tubes are rusty and probably should be replaced if I am leaving them since the motor is out. I would have to leave the one going to the EGR of course. Does anyone know for sure by removing them if there will be any problems (ie: check engine light, performance, etc). Any help would be appreciated. Anything else I should do while the engine is out?
Thanks.
edit: I am in Canada if it makes a difference.
Old Sep 25, 2005 | 01:30 PM
killaford's Avatar
killaford
ya man, replace the tubes.
lot easier now than later.
Old Sep 25, 2005 | 01:50 PM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State Chapters located near the bottom of the main forum page.
I am going to move this to the 5.8L forum. You will get some more help there seeing as how it is an Engine Specific question.
See ya on the boards!
-Matt
General Geoff
Dec 17, 2019 05:28 AM
kr98664
15
Sep 27, 2016 01:21 PM
putz88
Oct 12, 2015 08:37 AM
Toplait
May 17, 2015 09:33 AM
