35x12.5 how much lift?
there are only 2 or three available for the 77.5-79 f-250, skyjacker, rough country and one other, my favorite is skyjacker(what i run of course). rough country is known for sagging and poor quality. i beleive the skyjacker kit is around 500 dollars, plus shocks, you need to get a drop pitman arm along with a drop draglink too. also, i would highly recommend spending the extra 5 bucks to get the nitro shocks, and the stainless steel brake lines. the brakelines are plenty long enough, and they make your pedal feel firmer. lastly, if you can afford it, go ahead and go with the rear springs instead of blocks, it will be worth it, cause alot of axlewrap sucks.
you will probably have to get your driveshafts lengethed too. feel free to e-mail me and i can give you any details you need
hi
i'd go with 3" body and 3" suspension. body kit is cheapest and very effective the kits in summit are about $70.00 i would not recomend blocks in back, but if you use blocks their easy to make. i'd put traction bars on it if you have a lot of power under the hood. another way is to lower your spring shackels, which isn't hard if you have a drill, welder and some scrap metal. but what ever you do, make it safe and strong. and good luck.
there are a ton of web sites that you can find large tires on. here are some of them. www.4wheelparts.com www.tyres1.com www.ntwonline.com. if you call around and check the prices 4wheelparts will beat anyones price by at least 10 bucks.
'75 F-100 4x4, 4" lift
16x38.5x15 super swamper TSL
mini-spooled 9" rear end
390 w/ cam,headers,
and 4 barrell edelbrock
TRIED TRUE and FORD BLUE
390 w/ cam,headers,
the brakelines on f-250's and f-150's are different in the front, when i only had a 4 inch lift on my 250, my front brakelines just didnt cut it, they were badly cracked anyway. The reason i went the more expensive route on the brakelines is i wanted the strength of stainless steel, and the more reasuring feeling when im stopping.
In my opinion, i would always do the suspension lift first instead of the body, because it brings your frame up higher off the ground. The body lift does nothing for ground clearance without larger tires.
I run 35'3 with the Wild Horses 1.5" "Rockcrawler" spings for the early Bronco. In the rear I have 1" blocks. Unless you want a lifted look the 1.5" lift clears 35's. The only rubbing I have is a little on the rear fenders when four wheeling with the rear axle fully articulated. People say you need a lot more lift than you actually do.
