No Spark need help
Old Jul 9, 2002 | 09:56 PM
Bruin52's Avatar
Bruin52
No Spark need help
Old Jul 11, 2002 | 05:03 PM
gracie's Avatar
gracie
No Spark need help
1977 F250 460 CI Auto.
The truck turns over fine but won't fire.When you let of of the key it seems like it fires just a hair. It is getting fuel, and I have changed/tested the Modual,coil and Solinoid, but no luck. It died a few times yesterday when I would let of the gas and turn. Today It started right up then Died suddenly. Then it would start,but not idle, now nothing. Any suggestions would be great.
Old Jul 11, 2002 | 05:07 PM
impact's Avatar
impact
No Spark need help
Check the wiring going to the coil and the wires to the solenoid.May have a break in the wiring somewhere
Old Jul 11, 2002 | 05:08 PM
Vampiro's Avatar
Vampiro
No Spark need help
check your coil wiring and your rotar in the distrubutor. test all wires make sure they work and clean the connections to the coil
Old Jul 11, 2002 | 10:18 PM
Mike W's Avatar
Mike W
No Spark need help
Is the carb delivering fuel ok? Also, check the timing.
Old Jul 11, 2002 | 11:18 PM
tellico racing's Avatar
tellico racing
No Spark need help
Check the fusible link wire going to the hot side of the solenoid.had the same thing just yesterday,wire was burned up,replaced it and it took right off.
Old Jul 12, 2002 | 01:04 AM
Torque1st's Avatar
Torque1st
Posting Legend
No Spark need help
Some of these symptoms sound like the ground may be bad in your distributor or you may have a broken wire in the distributor pickup wiring either internally or externally. Try replacing the pick up module in the distributor with a known good unit.
Old Jul 12, 2002 | 09:31 PM
bryan_henry's Avatar
bryan_henry
No Spark need help
I had problems with that on my 78...was doing the exact same thing...turn over but not run...sometimes wold start for just a second then die again...all came down to the voltage regulator so you might give that a try
Old Jul 12, 2002 | 10:37 PM
thelonerangerxlt's Avatar
thelonerangerxlt
No Spark need help
Gracie, since it wants to fire when you release the key, I think it's a bad ignition switch. They are cheap and easy to replace. Good luck.
Old Jul 13, 2002 | 12:38 AM
Cowboy_351's Avatar
Cowboy_351
No Spark need help
start at the spark plugs and work your way back, ground out a plug and see if it is sparking, if thats all good, move back t othe coil, check the connections, when i put my tach in i lost good connection in the coil, could be important to check.
Old Jul 16, 2002 | 07:44 PM
ford4life69's Avatar
ford4life69
No Spark need help
My '79 had a problem. You would turn the key to start and it would start. As soon as you let go of the key and it returned to the on position, it would die. Somehow it was loosing connection. I got the truck back from my dad and the ingintion cylinder was turned. As soon as I turned the cylinder back to where it belonged, it quite dying. Don't know if that has any relevance to anything but once I got that cylinder turned back, a lot of my problems went away. My blower motor started blowing, my right interior blinker light started blinking, and it quit dying as soon as the starter stopped. Just thought I'd throw it ur way.
Connie (only Ford luvr in the family!)
'79 f100 "Silver Ghost" (my baby)
'83 f100 "The Ford" (my first)
'85 f150 "Old Blue" (my next project)
Old Jul 16, 2002 | 07:55 PM
shortbedford's Avatar
shortbedford
No Spark need help
Hey, check your pickup coil in the distributor. check the ohms i bet its bad.
