Bronco II Ford Bronco II
Transfer case swap! Help!!!
Old Sep 24, 2005 | 06:43 AM
Flatbed392's Avatar
Flatbed392
Hey all,
My son-in-law has an 85 BII with a 2.9/5-speed. The output shaft on the transfer case snapped off clean. He just got another BII ( 85 I think ) as a donor truck. Only problem is, the donor truck is an automatic. My question is will the transfer case from the auto interchange with the 5-speed with out too many problems ? Thanks in advance for any response!
Don
Old Sep 24, 2005 | 01:48 PM
Flatbed392's Avatar
Flatbed392
Sorry about that all,
The two trucks above are both 1989. The donor truck is also a 2.9.but with an automatic.
Don
Old Sep 24, 2005 | 09:35 PM
GrayRanger4x4's Avatar
GrayRanger4x4
If both are mannul t-cases they will work,if both are elec,shift they will work. If one is elec. and you got a mannul one in your truck then you will need ALL the wireing and controls for the elec.one. if your truck is a elec shift you will need ALL the lickage from the donor truck to make it work.Hope this makes sense.
Old Sep 25, 2005 | 01:02 PM
Flatbed392's Avatar
Flatbed392
GrayRanger,
Thanks for that info. Yes, it did make sense. The donor truck has electric shift and the truck it is going into is manual. Can the electric one be changed over to manual without too many problems?
Thanks again,
Don
Old Sep 25, 2005 | 02:16 PM
GrayRanger4x4
Thumbs down
You will have to swap ALL the wireing for it to work.I'm not sure if the manual truck has the power conections to do that swap.Someone with more knowlage the I would have to help you with that.I don't think I would want to do it.There a bunch of elec.stuff to swap.
Try to find you another manaul t-case.
Old Sep 25, 2005 | 02:31 PM
GrayRanger4x4
You might be able to swap the out put shaft between the 2 T-case.I think thats all the same.The only diffrance is how the shift.Worth looking into.
Old Sep 27, 2005 | 04:02 PM
Flatbed392's Avatar
Flatbed392
Thanks for the info. Will let you know what we do and how it turns out as soon as I can get him busy on it !!
Old Oct 8, 2005 | 08:02 AM
Flatbed392's Avatar
Flatbed392
Well, he is on the road again! He finally decided to go to a local boneyard and get the right t-case. Now he is gonna take what he wants off the donor truck and part the rest out.
Thanks for the help!
Don
Old Oct 8, 2005 | 04:14 PM
tbolt 460's Avatar
tbolt 460
what color interior does the donor rig have??
twistedtaco
Engine Swaps
Apr 27, 2016 10:50 PM
jecsd1
Bronco II
Apr 4, 2014 05:36 PM
nolowbronco
Bronco II
Nov 28, 2011 10:49 AM
coyote0003
Bronco II
Sep 1, 2007 04:09 PM
ewstrand
Bronco II
May 18, 2006 07:20 PM
