axle?
Old Jul 12, 2002 | 10:59 PM
bryan_henry's Avatar
bryan_henry
axle?
rear end gear ratio I have other then from the VIN code. The sticker is on the truck but there is no numbering in the axle section
Old Jul 13, 2002 | 08:44 PM
tetraruby's Avatar
tetraruby
axle?
Check the metal tag usually on one of the bolts at the rear axle wear the third member bolts into the pumpkin. The second line of text, first three digits should give you the information you want. You'll probably need a a rag and / or wire brush.
Old Jul 14, 2002 | 12:01 PM
bryan_henry
axle?
[updated:LAST EDITED ON 14-Jul-02 AT 01:06 PM (EST)]thanks for the info but still not real sure what I am looking at. I found the tag and the numbers are
2 72 D7TA JA
603903-1
does this mean anything to anyone else? Thanks
Old Jul 14, 2002 | 01:25 PM
tetraruby's Avatar
tetraruby
axle?
...or maybe it was the first line of text...sorry about that. I'd check the first line again...particularly the 2 72. My best guess is a 2.73 & since you found no "L" - an open differential. I'm sure another member here can give a second opinion.
Old Jul 15, 2002 | 09:54 AM
ledgeclimber's Avatar
ledgeclimber
axle?
The "D7" means 1977. The 603903 is the Bill of Materials number but this number is not on the Dana site or my Dana books. Check it again. I did not see this entire thread. Is it a rear or front?
Ledgeclimber
Old Jul 15, 2002 | 06:06 PM
bryan_henry
axle?
[updated:LAST EDITED ON 15-Jul-02 AT 07:12 PM (EST)]It is rear...2wd truck...I rechecked it and those are the right numbers. Thank you so much for your help
Old Jul 16, 2002 | 11:22 AM
ledgeclimber
axle?
Here is another site but it is not on there either.
http://www.patooyee.com/Dana/By%20BoMN.htm
Old Jul 16, 2002 | 05:59 PM
bryan_henry
axle?
[updated:LAST EDITED ON 16-Jul-02 AT 07:15 PM (EST)]Haha...thanks for the help. I guess the world may never know what rearend is under my truck. I don't think 2 72 is right though. Gets off the line way too fast for that to be the case.
Old Jul 16, 2002 | 06:32 PM
tetraruby's Avatar
tetraruby
axle?
Support the rear axle with jackstands, put it in neutral, and count how many times the drive shaft rotates per tire rotation. You'll also find out if you have limited slip or an open differential for sure.
Old Jul 16, 2002 | 07:35 PM
bryan_henry
axle?
the driveshaft turns 1 and a quarter turn per tire rotation. The axle is limited slip. What does the 1 and a quarter turn mean?
Old Jul 16, 2002 | 07:59 PM
Mil1ion's Avatar
Mil1ion
axle?
Why not just pull the cover off and count the teeth on the pinion gear & ring gear > then do the math.
This is a NO Fault method.
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Jul 16, 2002 | 08:13 PM
shortbedford's Avatar
shortbedford
axle?
Hey bryan are you sure you counted that right you either have very small tires or extremely low gear ratio.Make sure you mark that driveshaft and tire to make sure you count it correctly and try it again.
Old Jul 16, 2002 | 08:31 PM
bryan_henry
axle?
doesn't sound right to me eaither. I have 70 series tires....don't have the exact measurements but they are larger then stock and I did mark both driveshaft and tire. I think I will just have to pull the cover. Thanks
Old Jul 16, 2002 | 08:40 PM
Jermafenser's Avatar
Jermafenser
axle?
One and a quarter sounds like a 4.10...or the other way? I have never done the "jack-up-and-turn" method.
Old Jul 16, 2002 | 08:45 PM
Jermafenser
axle?
