Is 400hp Possible
Old Sep 23, 2005 | 11:14 PM
bigexpo's Avatar
bigexpo
Exclamation Is 400hp Possible
I Ahve A 5.4 L With The 265hp So I Gues Its The Newer Heads On It. And I Want To Try To Get 400hp Without Using A Supercharger, Turbo Or Nitrous. What Should I Get And Is It Possible, Or Could I Even Exceed This
Old Sep 24, 2005 | 12:10 PM
pfogle's Avatar
pfogle
It's possible. I'm not sure how streetable it will be tho.
Old Sep 24, 2005 | 01:11 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
High-compression pistons, port & polish, larger valves, cam, roller-rockers, larger fuel injectors, bigger fuel pump, cold air intake, exhaust system, computer chip/programmer, MSD ignition, spark plugs & wires...
Did I miss anything?
Old Sep 24, 2005 | 05:51 PM
bigexpo's Avatar
bigexpo
damn well i dont want to get in the eninge that much maybe switch teh heads out but thats as far as i want in
Old Sep 24, 2005 | 08:32 PM
triton_2002's Avatar
triton_2002
Why don't you want to use a supercharger? A tweaked lightning will pump out 400 hp all day long and still be civilized.
Old Sep 25, 2005 | 07:22 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
4V heads...
My Falcon ute (see gallery) makes an "alleged" 389hp at the flywheel from the factory without any form of forced induction.
In actual fact though, many 4V 5.4's here have been on chassis dyno's that indicate that they are making over 400hp.
Old Sep 25, 2005 | 07:25 PM
triton_2002
Originally Posted by BigF350
4V heads...
What other differences are in the aussie 5.4's besides the 4v heads?
Old Sep 25, 2005 | 08:59 PM
LxMan1's Avatar
LxMan1
The 2000 Cobra R have a 5.4L DOHC engine and it made 385hp. If yu are using it in a heavy truck, to get 400hp will require larger cams and the usable rpm range will be too high for a truck and will be lacking in needed torque.
Supercharging or turbocharging is the easiest way and still be tame enough to drive everyday.
Old Sep 28, 2005 | 04:24 PM
bigexpo's Avatar
bigexpo
whats up with the 4v heads your talking about, can i just swap them out on my 99 or what. and i dont want a supercharger because its to much money and i heard it lowers your gas mileage
Old Sep 28, 2005 | 07:44 PM
triton_2002
You want 400hp and your worried about gas milage? A supercharger would not decrease your gas milage much, unless your always on the boost
Old Sep 29, 2005 | 09:46 AM
l-m tech's Avatar
l-m tech
for the money you would have to spend for the 4 valve heads like,heads,intake,front over,chains,guides ,valve covers,wiring harness,computer, and so on.you could buy a super charger and do the install in a day in your driveway.
Old Sep 29, 2005 | 03:17 PM
bigexpo's Avatar
bigexpo
i just think it would be cool to have the 4v. im more of a person who wants to do something diffrent than everyone else, and yea you have a good point but still it would be caool and i couldnt put the supercharger in anyways cuz i dont have much experience cuz im only 16
