brake lines
Old Sep 23, 2005 | 05:07 PM
lenny1carl's Avatar
lenny1carl
brake lines
had a blow out on my brakelines. is it gonna be a tough fix. any help is appiceated
Old Sep 23, 2005 | 07:15 PM
quicklook2's Avatar
quicklook2
very easy to do.
i took out brake line that was leaking, measured it, went to local auto parts store, with line and fittings, and matched new line/lines up.
if you need to bend them you can use your hands.
they have stock lengths and you may need to connect two lines for longer lengths, i did.
ask parts man for help so you get matching parts.
it is optional to tape line as you bend to old line to keep shape.
you need someone to help bleed brakes. soak bleeders with power blaster or something.
write if you need more help.
Old Sep 23, 2005 | 08:21 PM
Popa Tim's Avatar
Popa Tim
Welcome to Ford-Trucks!
I would pick up a spring tubing bender to bend the brake lines, it helps them keep thier shape. If the car parts store doesn't have one then try the hardware store, I saw a set in Home Depot last week. They are real easy to use.
As for bleeding the brakes, start with the bleeder furthest from the master cylinder and work your way closer. They do make 1 man bleeder kits if you don't have someone to help. Let us know if you need instructions on how to bleed them.
Cheers,
Popa Tim
Old Sep 23, 2005 | 09:24 PM
quicklook2's Avatar
quicklook2
popa-tim-
in most cases i use a tube bender on brake lines, but on the main f150 lines they are almost all straight with very little bends.
i found i did not need to use one.
on some you may have to use a bender
Old Sep 24, 2005 | 07:44 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 24, 2005 | 12:13 PM
plapczynski's Avatar
plapczynski
I had a line go out in my 93 F150 last week. Just as I pulled in a parking lot the pedal bottomed out, that was after 3 hours of highway and county road driving (thankful I went to church last week!).
The line I had to replace was the one that ran from the right front to the left front.
A fair amount of bending and some time with the double flairing tool. You could run it with two separate lines if you don't want to flare the lines yourself and just put a coupler in-between. The fix ran about $10.00 with fluid. It took about 2 hours total.
The hardest part-
Cracking open bleeder valves that hadn't been open in a while (6 point socket and PB Blaster got it).
Be careful not to cross-thead the fittings!
Paul
Old Sep 25, 2005 | 02:44 PM
lenny1carl's Avatar
lenny1carl
brake lines
well of course i got into it w/ all your help... i fixed the leak w/ line from napa. & of couse the next weakest section blew. fixed that, & next spot went. needless to say i have all new brake lines. done in the driveway no less. that sucked but napa had a great selection of lines. fittings , & the tools you all suggested. normally i wouldn't napa my money as they are pricey as hell, but i have to say i got this done for under $150. try paying a garage that for the work done. 1 bit of advice i'd offer--- DO NOT ask the wife to help in the bleeding process. pay the garage to do the job. it's cheaper than the lawyer you will need for the divorce. thanks alot guys .
Old Sep 25, 2005 | 05:24 PM
quicklook2's Avatar
quicklook2
hahahahahahahahaha
that is why i said have a friend help you bleed the brakes. next time listen to me.
Old Sep 26, 2005 | 05:35 AM
lenny1carl's Avatar
lenny1carl
brake lines
sorry quicklook i missed that in your post. how right you were
Old Sep 26, 2005 | 09:29 AM
DAJF150's Avatar
DAJF150
Hey guys, just to add something. someone mentioned the one-man brake bleeder kit. I bought one last week and did my other car. Hand vacum pump w/ adaptors and 4oz. filler cup thing. I seem to be always by myself on all past cars over the years. It cost about 60 bucks but all worth it. Pump at each end, and move on. Can also use the vacum pump for testing vacum stuff as well. You only get one chance to open up/loosen brake lines, and bleeders. Thats the pain part....
Get R Done before winter.... Doug
Old Sep 26, 2005 | 09:52 AM
lenny1carl's Avatar
lenny1carl
brake lines to dajf150
that sounds like a worthy investment. i'd like to know whre you found that tool. i didnt mention in the 1st post that im disabled & that i live in a place surrounded by elderly ppl. not alot of ppl that could help besides my wife, & that was a disaster. lol. agian thanks to all that replied
Old Sep 26, 2005 | 09:59 AM
DAJF150's Avatar
DAJF150
Talking
I bought that brake/vacum kit a CarQuest auto part store. Napa should also have it as well. Or Summit/Jegs mail catalog will have a kit.
I always get stuck waiting for a friend/family member to get stuck w/ job. I am not married- good or bad dont know.
That reminds me of my parents arguing all the time each time to hook up the camper or back in the rig. lol.
Doug.
Old Sep 26, 2005 | 10:10 AM
lenny1carl's Avatar
lenny1carl
ty alot daj for the heads up. i like the vac checking abilities. all the info i got on this thread was really helpfull. and thanks to everyone for their help. i know where to come for advice
