Sponsored by: Real Truck
Shifting problem?? Need some help...
Old Sep 23, 2005 | 05:01 PM
Bowcop's Avatar
Bowcop
I have an 01 SD 250 with the 5.4 auto tranny...
The last few days it has been shifiting erradicly(sp) I will be going along at say 35 mph turning about 1500 rpms and it will suddenly shift down with no increase in throttle from me..
What gives??? Do I have a sensor problem or something else.
The only thing I have done to the rig in the last few weeks was put a differant exaughst system on it.
PLEASE ADVISE!!!
Thanks all,
Tim
Old Sep 23, 2005 | 05:11 PM
FortyFords's Avatar
FortyFords
Chk the wiring to the VSS sensor mounted on the rear diff,you might have disturbed it.
or it maybe going bad .
clean the dirt off around the area before removing,you don't want any of that dirt falling into the gear area.
Rich
Old Sep 23, 2005 | 05:14 PM
Bowcop's Avatar
Bowcop
Thanks Rich,
Is that the only sensor on the rear diff? Is there anything I should look for besides the obvious? (unplugged, ripped etc)
Old Sep 23, 2005 | 05:18 PM
FortyFords's Avatar
FortyFords
Besides the obvious broken wires loose connection.no but if you pull the sensor out of the rearend and it is covered in gray particles of metal think about a fluid change soon.you can get a new sensor pretty cheap! might as well have one in your hand before removing.
Rich
Old Sep 23, 2005 | 05:22 PM
Bowcop's Avatar
Bowcop
Thanks Rich, I will check that..
Is there anything else that I should check?
Old Sep 23, 2005 | 05:37 PM
Bowcop's Avatar
Bowcop
Man, how do you unplug that thing???
I want to make sure I am looking at the right plug. In the front center of the rear diff is a black flat plug that has wires in it that go to the front of the truck. Am I on the right one?
Old Sep 23, 2005 | 05:41 PM
FortyFords's Avatar
FortyFords
your on the right one,take a flashlight or lead light .should be a little locking tab to release the plug.
Rich
Old Sep 23, 2005 | 06:11 PM
Bowcop's Avatar
Bowcop
Ok,
I checked the plug, it was nice and tight and it looks brand new inside, can not see any problem there......
Anything else?
