Bed crossmember/ mount size
Old May 18, 2017 | 03:02 PM
Kakejelly13's Avatar
Kakejelly13
Got a new bed and wanted to put it on, crossmembers are rotted to hell, its an 8ft bed on an 02 f250. Anybody know the size of the cross members so I can cut out new ones? Thanks in advance
Old Jan 14, 2018 | 04:39 PM
BlackTruckDave's Avatar
BlackTruckDave
Kakejelly13 what did you end up finding for the sizes?
Old Jan 24, 2018 | 11:03 AM
FuzzFace2's Avatar
FuzzFace2
If it is any thing like my 81 F100 depending where the CM sits they will be different height as the frame is not flat from cab on back to the end.
Dave - - - -
Old Jan 24, 2018 | 11:50 AM
BlackTruckDave
Dave - - - -
I have a 2008 F350...I'll safely assume slight difference
Old Jan 25, 2018 | 10:01 AM
FuzzFace2's Avatar
FuzzFace2
I know you have a newer truck but look at the frame.
From back of cab to end of frame at the rear is you frame flat front to rear?
Bet not but the floor of the bed is flat & level.
How do you think they over come that?
Your best bet is to measure what you have now to make new ones.
Dave - - - -
Old Jan 25, 2018 | 10:43 AM
BlackTruckDave
Dave - - - -
No disrespect but I need the measurements because mine are rotted. Also very big difference between 2008 F350 Superduty and a 1981 F100. Thanks for trying though.
Old Jan 30, 2018 | 08:38 PM
FuzzFace2's Avatar
FuzzFace2
No disrespect just trying to help..
I had none at all on my flare side and was able to come up with something that works. Should not make any difference if it is a 1930 or 2018 truck.
If you have the floor to measure off from to the top of the frame that is all you should need. Measure at each spot the cross members should be.
Note before you measure make sure the bed body lines line up with the cab body lines.
Dave ----
Old Feb 28, 2018 | 08:56 PM
Kakejelly13
Not mine personally, will get measurements when the ones I ordered come in
Old Mar 9, 2018 | 07:08 PM
Kakejelly13
Well, I wouldnt order something like this again unless I had to, this being said hope to save someone from dropping $300. Friend replaced his bed in his chevy and said its a bitch to get the body lines to match up so exact measurement could be pretty usefull. From left to right, 60 7/16 long, 3 1/8 tall, 4 1/2 wide. 52 1/16 long, 1\" tall, 3 3/4 wide. 46 1/4 long, 2 1/4 tall, 4 1/2 wide, and finally 46 1/4 long, 2 1/2 tall, 4 1/2 wide.
Old Mar 10, 2018 | 08:15 AM
BlackTruckDave
Thanks for sharing that. I'm guessing that the front "sill" of your bed is good? It doesn't come with the kit which sucks for me cause it's an additional cost. Ford did not have to cheap out with the cross members like they did but hey thats the new way...ECONOMY...just keep shopping. Cheers for your post!
Old Aug 5, 2020 | 03:21 PM
Adam Grant17's Avatar
Adam Grant17
Originally Posted by Kakejelly13
Well, I wouldnt order something like this again unless I had to, this being said hope to save someone from dropping $300. Friend replaced his bed in his chevy and said its a bitch to get the body lines to match up so exact measurement could be pretty usefull. From left to right, 60 7/16 long, 3 1/8 tall, 4 1/2 wide. 52 1/16 long, 1" tall, 3 3/4 wide. 46 1/4 long, 2 1/4 tall, 4 1/2 wide, and finally 46 1/4 long, 2 1/2 tall, 4 1/2 wide.
Is this on a long bed or short bed or is there a difference? Thanks.
Old Aug 5, 2020 | 03:27 PM
Kakejelly13
this was on a long bed but I don’t think it makes a difference.
Old Aug 5, 2020 | 03:41 PM
Adam Grant17
sweet so you’d recommend buying metal to meet those dimensions rather than buying the crossmember kit ?
Old Aug 6, 2020 | 12:28 PM
Kakejelly13
Depends on how much time you wanna spend on it, if I remember correctly the bed bolts went through the crossmembers so you’d have to drill into The ones you cut out. I don’t have measurements for that.
mrchips63
6.7L Power Stroke Diesel
15
Feb 12, 2016 08:48 PM
C. Lee Colbert
1983 - 2012 Ranger & B-Series
Aug 18, 2013 01:00 AM
baitmaster
Aug 9, 2005 06:04 PM
reguy
Ford vs The Competition
Feb 26, 2005 05:47 AM
