Transmission Swap
Old Sep 23, 2005 | 06:12 AM
Clif Jones's Avatar
Clif Jones
Transmission Swap
I was just given a 1987 ford ranger extended cab, body is in good shape. It has a 2.9, automatic tranny (floor shift) and 2wd. The tranny is trashed.
Ive been trying to find an A4LD for the past month with not luck.
How much of a pain is it to convert to a 5 speed and which type of tranny will bolt up?
Thanks
Stuck with no gears.
Old Sep 23, 2005 | 01:15 PM
G2IC_Wraith's Avatar
G2IC_Wraith
A Ranger trans with the code FM146 (or similar) made by Mitsubishi will bolt right up to your 2.9L, as long as it came from a 2.9L.
It will be a BIG pain to do it, but it can be done. Your best bet would be to find a wrecked Ranger of similar year and use as a donor. Or one with cracked heads like the 2.9L is **** to doing when it overheats.
Old Sep 24, 2005 | 01:18 AM
Monty06's Avatar
Monty06
you can find an a4ld on quite a few fords not just rangers
for example a bronco2,mustang,aerostar,thunderbird etc...
need more info just ask away. by the way welcome to fte.
Old Sep 24, 2005 | 01:24 PM
Clif Jones's Avatar
Clif Jones
Monty06
Thanks for the info but still no luck. Ive looked from Danvile Va to Va Beach va.
Thanks and yes Im one of the new guys on the block.
