Bed light?
Old Sep 22, 2005 | 09:21 PM
LACityFD's Avatar
LACityFD
Bed light?
Here's my problem:
I recently put a snugtop lid on my 05 SCREW short bed. It's awesome except for the fact that now it is impossible to see in there when it's dark out. I was thinking of running some LED type bars under the bed rails -- if such bars even exist.
Anybody have any other ideas?
Thanx!
-Louie
Old Sep 22, 2005 | 09:27 PM
Lizardking's Avatar
Lizardking
I had the same problem on my 95 Chev. I found the easist solution was to get a battery powered RV light attached under the cover near the tailgate. It was going to be a PITA to run the wiring and figure out a spot for the switch. It gets hot under there but I never had any problems with leaking batteries.
Old Sep 22, 2005 | 09:39 PM
Ruckus's Avatar
Ruckus
I did the same as Lizardking. I installed a battery type light on each side underneath my ARE lid. I have never used them, but maybe some day. Good Luck!
Old Sep 22, 2005 | 10:15 PM
kingfish51's Avatar
kingfish51
One thing you may be able to look at and try is using the halogen string lights that they use under kitchen cabinets. I believe they run off 12 volts.
Old Sep 23, 2005 | 08:01 AM
gpeade's Avatar
gpeade
I was under the assumption that a light was an option on most caps. It seems to me that everyone I know with a lid has a light under it. I just assumed it came with the lid. silly me for assuming!!
Old Sep 23, 2005 | 08:11 AM
kingfish51's Avatar
kingfish51
Usually a cab high cap has that option, I have seen very few bed covers with that option.
Old Sep 23, 2005 | 09:45 AM
KevinM's Avatar
KevinM
My ARE hard painted tonneau came standard with carpeting and a remote light
Old Sep 23, 2005 | 11:33 AM
Ruckus's Avatar
Ruckus
KevinM, Is your light battery operated or hard wired and what did you mean by remote light? Thanks
ChrisAdams's Avatar
ChrisAdams
There is a great little magnetic light I got at Wallmart. It's a beige thing, but it fits nicely against the rear under the tail lights on the inside. You do forget it there if you don't use it for a while.
It's a Coleman and under 15 bucks.
Chris
Old Sep 23, 2005 | 01:52 PM
IslanderXLT's Avatar
IslanderXLT
LED Tap Lights?
http://www.nifty-stuff.com/mini-tap-light.php
http://www.safetycentral.com/safetyc...taplimoan.html
