PCV breather cap question
Old Sep 22, 2005 | 08:42 PM
fordbeast_80's Avatar
fordbeast_80
Ok The PCV connected to a plate underneath my 2 bbl carb and this is basically an emissions thing it feeds the vapor into the engine to be burned up right?
So with the 4 bbl on it and I switch to the breather caps with no hoses attached to them will this hurt anything?
I was wondering because I can see vapor coming from the breather cap?
Old Sep 22, 2005 | 08:46 PM
biz4two's Avatar
biz4two
Arrow
That is a good question...
On my setup, I have the PVC connected, but not the Oil breather cap. I am curious on any responses...
Old Sep 22, 2005 | 09:48 PM
76supercab2's Avatar
76supercab2
For the PCV system to work, air has to flow through the engine. It is preferable that the air is filtered before it enters the crankcase. The FE has the breather cap on the drivers side valve cover. That is the intake for the PCV system. Filtered air is drawn from the air cleaner assembly into the crankcase. This air is pulled through the crankcase and out the pcv valve on the passenger side valve cover. The crankcase gases are then drawn into the intake and burned. For the system to work , the air has to flow. If you replace the oil fill cap or air cleaner assembly, us a cap that has filtering ability.
If you remove the pcv valve and just use breather caps on both sides, it's not good for the engine. You shouldn't have pressure building in the engine because the 2 breathers should allow the gasses to escape readily enough. But the gases that are in the crankcase can be corrosive. Without the PCV system, those gases can linger and not be drawn out of the engine.
Old Sep 23, 2005 | 11:43 PM
plowpusher's Avatar
plowpusher
your engine is an air pump pistons going down create pressure in the crankcase pcv stands for POSITIVE crankase ventilation it sucks the air out of your cankcase it is not an emissions thing you will blow the seals out of your crankcase it does not hurt perfomance it will actually help it by relieving crankcase back pressure
Old Sep 24, 2005 | 12:16 AM
Hypoid's Avatar
Hypoid
All that and it does help keep deposits down like 76super said. In this great state PCV is listed emission equipment-by year anyway.
Old Sep 24, 2005 | 01:27 AM
Bear 45/70's Avatar
Bear 45/70
The pressure in the crankcase is created by blowby past the piston rings, (not the pistons going up and down as everytime a piston comes down another is going up, equalizing the volume in the crankcase) which cause the pressure to escape thru the road draft tube in the old days, down under the car onto the road. And yes, the PCV system is an emissions thing because they want the engine to burn this stuff and not dump it onto the road and into the atmosphere. The PCV system has nothing to do with improving preformance. And no you will not blow any seals unless you have less than enough vents. If he uses the vents on the valve covers only, without PCV system, then he will blow crap all over his valve covers. Run the PCV system with the 4 barrel, there will be a port for the system to hook to on the carb or the spacer.
Old Sep 24, 2005 | 12:17 PM
biz4two's Avatar
biz4two
Arrow
That's good info Bear! But what about the other side where the oil cap is? Is it necessary to connect oil cap to the air cleaner? Or is it possible to only have the PCV system connected as you suggested and have the oil cap vent into the atmosphere?
Thanks!
biz
Old Sep 24, 2005 | 12:33 PM
Bear 45/70's Avatar
Bear 45/70
Thanks!
biz
The side connect to the air cleaner is the inlet to the crankcase and the outlet side (passenger side normally but not a requirement, run it the other way if you want to) is where the PCV valve goes with a groment and a line to the large carb vacuum fitting. I once saw a guy use an old road draft tube intake and have the PCV valve come off the back of the manifold and had breathers on both valve covers. The is no law that says you must run the inlet side to the air cleaner. Even I remember when engines came without that and just had a regular breather on the one or both valve covers, but you had to clean it every tune up or it could plug up.
Old Sep 24, 2005 | 07:04 PM
76supercab2
Thanks!
biz
You could do that but you will be drawing unfiltered air into the crankcase.
Old Sep 24, 2005 | 09:53 PM
Bear 45/70's Avatar
Bear 45/70
Are you under the impression that there is no filtering material in the breathers. There is, it just doesn't keep out real fine stuff and as there is oil build up in the breather cap it filters even better.
Old Sep 24, 2005 | 10:28 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
On the 68-69 FE trucks the air for the valve cover comes off a 90 degree pipe stub on the outside of the air filter housing which is unfiltered air. The stainless steel "Brillo" material inside the left and right filler cap needs to be cleaned once a year as well the PCV valve. Soak in a gallon can of Berrymann's carb cleaner, rinse then repaint outside. I added another 90 degree stub on the inside of the air filter housing then connected a filter so the motor gets clean dust free air inside.
.....=o&o>.....
Old Sep 25, 2005 | 09:58 AM
snoopypup's Avatar
snoopypup
No holes in Valve Covers
I am building a 406 with a Blue Thunder single 4barrel intake. I have no valve cover holes. It sounds like using a PVC on the rear somehow and the oil fill cap as the intake filter is the proper method?
Old Sep 25, 2005 | 05:20 PM
"Beemer Nut"
If you have cast aluminum covers they should have plugs that you knock out for PCV and oil fill, that's what a set of Mickey Thompson covers I have. Older Cal-Custom covers came with the holes when new.
.....=o&o>.....
Old Sep 25, 2005 | 08:23 PM
76supercab2
.....=o&o>.....
That's true. But I believe there should be a filter inside the air cleaner housing on the other side of that elbow. It's called a breather filter and AutoZone lists Fram BA24 as the part for a 68 or 69.
http://www.autozone.com/servlet/UiBr...ction=loadPage
Assuming that they have the correct part listed.
Old Sep 27, 2005 | 12:37 AM
tomcasino's Avatar
tomcasino
PVC system
snoopypup,
That will work. My 304 (Jeep) has a PVC valve in the rear of the intake, a tube in front of the intake to fill oil and no holes in the valve covers.
