trans switch
Old Jul 19, 2002 | 01:27 PM
leadmic's Avatar
leadmic
trans switch
Old Jul 20, 2002 | 06:07 AM
smile5480's Avatar
smile5480
Post trans switch
I have a 1973 F100 with 302 and 3 speed on the colom. Will a (light) 4 speed (on the floor) 3 speed over drive from a 1978 F150 with a 302 slip right into my 73 or is there additional work to do.
New at it Thanks
Old Jul 20, 2002 | 11:05 AM
Jimbare's Avatar
Jimbare
all alone in the world
trans switch
drive shaft may be to long or to short, but other than that it should all fit.
Old Jul 20, 2002 | 02:54 PM
Jermafenser's Avatar
Jermafenser
trans switch
The 302 has an 335 series small block bellhousing pattern. You would want to find an 4 speed transmission with the 335 series bellhousing pattern. 300 I6, 302 V8, 351W V8 shares the same pattern.
If you find a car/truck with the engine stated above and you see a 4 speed, you've hit the mother lode.
Hope this helps.
Old Jul 20, 2002 | 04:56 PM
Mil1ion's Avatar
Mil1ion
trans switch
Actually Jerm, The 351C,351M,400 are the 335 series engines.
The 289,302,351W,300I6 share the V-90 series engine bolt pattern for the tranny.
[font color=red]Dennis
FTE Assistant Adminstrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Jul 20, 2002 | 06:44 PM
Jermafenser
trans switch
Eh? I thought the 335 series was the 289, 302, 351W? Ergh, why can't Ford kept it simple!
So what 289,300 I6, 302, 351W belongs to? Just the 90 degrees V8s?
Old Jul 20, 2002 | 07:13 PM
Mil1ion's Avatar
Mil1ion
trans switch
>>The 289,302,351W,300I6 share the V-90* series engine bolt
>degrees V8s?
The 221,260,289,302,Boss 302,351W are in the V-90* engine series,
The I6 obviously is not a V-90*,it just shares the same Transmission bolt up pattern
[/font]
[/font]
Old Jul 20, 2002 | 08:38 PM
bandit99's Avatar
bandit99
trans switch
Just to set the record straight guys, the 351c (not the 351m)of the 335 series engines uses the small block bellhousing pattern and motor mount patterns. And a note on the 3spd manual overdrive, be very wary as these were notoriously weak trannys, many developed problems with as little as 60k to 70k miles.
Old Jul 20, 2002 | 08:56 PM
tetraruby's Avatar
tetraruby
trans switch
??? I can tell this one isn't over...
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
