Seat Belts???
Old Sep 21, 2005 | 10:58 PM
jomes's Avatar
jomes
Seat Belts???
Hey guys what kind of shoulder belts are you using if you have them. I am looking around the net but shoulder truck belts are hard to find.
Andy
Old Sep 21, 2005 | 11:08 PM
imlowr2's Avatar
imlowr2
Welcome to FTE... Most of the trucks I've noticed don't have shoulder belts, however I have seen a few where they mounted the shoulder belt to the crossmember on the back panel which goes from the rear window to the door, just above the (on a 56) gas tank filler tube. The ones I've seen mostly came from 70's style Mustangs that have the rubber shield that snaps over the mounting bolt.
Old Sep 21, 2005 | 11:20 PM
jomes's Avatar
jomes
Thanks I have been looking at the later mustang seatbelts, but of course all of the belt reels are ugly since they are inside of the trim panel. I will look at the 70's stangs.
Andy
Old Sep 22, 2005 | 06:45 AM
LEckart's Avatar
LEckart
I used later model seats that have the 3-point belts built in. Did this because the PO did not consider belts before the truck was painted.
Old Sep 22, 2005 | 08:48 AM
SteV8e's Avatar
SteV8e
I have lap belts and I'm considering upgrading to shoulder belts.
LEckart:
Do you have buckets or bench seat? Out of what vehicle did you get the seat(s) with built in 3-point belts?
Thanks
Old Sep 22, 2005 | 09:38 AM
51ford fan's Avatar
51ford fan
Here is a list of a few companys selling Seat Belts.
http://www.julianos.com/
http://www.andoauto.com/
http://www.gemstreetrods.com/
http://www.corbeau.com/
http://www.cerullo.com/
Hope this helps.
Rod
Old Sep 22, 2005 | 09:45 AM
fatfenders56's Avatar
fatfenders56
I have used the Juliano's belts in several different cars and have been very happy with them. Be sure to get the anchor plate kit and FOLLOW THE INSTRUCTIONS!!!!
Old Sep 22, 2005 | 09:51 AM
cigarxtc's Avatar
cigarxtc
With some custom fabrication I was able to use the rear top cab corner supports in my '50 F1 for the shoulder point for some early 90's Mustang 3 point belts. But if this is for your '54 pickup, I can't recall if you have any cab support brackets in the upper cab corners to do that with?
Old Sep 22, 2005 | 10:07 AM
Jag Red 54's Avatar
Jag Red 54
On the 53-56 it is necessary to weld in a curved piece of steel that is connected at the left, right and bottom of the plate. I boulght my three-point belts from the supplier who travels the auto swap meets up and down the state. Good luck, Jag
Old Sep 22, 2005 | 10:12 AM
amish77's Avatar
amish77
the 70's style trucks also had the three point belts. mine has decently nice metallic cover on the reel.
Old Sep 22, 2005 | 04:50 PM
snipa's Avatar
snipa
just put mine in my 53
shoulder 3 point type from mid-fifty
bolt in brackets
80 bucks for the set
they fit good and I'm glad I have them
Old Sep 22, 2005 | 04:58 PM
SteV8e's Avatar
SteV8e
I've heard that bolt in, but am unclear to what the mounts bolt. Is the anchor point rock solid?
Thanks
Old Sep 22, 2005 | 07:40 PM
Col Flashman's Avatar
Col Flashman
I found an Original set from '58 that I'm going to be installing.
Though I'll probably replace the Webbing due to its age.
Andy
Old Sep 23, 2005 | 12:55 AM
Steve_B's Avatar
Steve_B
Thanks
There are a couple of pictures in my gallery "Seatbelts" of my mounting brackets
I made my own and welded them in bit the principle is the same
Stephen
Old Sep 23, 2005 | 07:49 AM
Brian_B's Avatar
Brian_B
Nicely done Steve_B. I like that install.
