Ignition on my 390
Old Jul 22, 2002 | 02:05 PM
Mil1ion's Avatar
Mil1ion
Ignition on my 390
Old Jul 22, 2002 | 08:06 PM
76_F150_390's Avatar
76_F150_390
Ignition on my 390
I finally got done with putting my 79 cab on my 76 frame and got everything hooked up but I don't have any spark. i have about 6.8v running into the coil from the ignition module and about 13.8v coming from the batt./ignition switch.--but there is nothing coming out of the coil. I have already tried putting in a known good coil and ignition module but still got nothing. I have also tested the pickup coil and that checks out o.k. Any suggestions/advice on what to do next? anything else to check?
thanks for all the help
Old Jul 22, 2002 | 08:45 PM
sparky's Avatar
sparky
Ignition on my 390
Try jumping 12 volts direct to the coil plus and see if you can start it. This will bypass the ignition system, dont run it for hours and hours like this
Let us know if it starts, then we can go from there.
Sparky
Old Jul 22, 2002 | 09:27 PM
76_F150_390
Ignition on my 390
I tried jumping 12 volts directly into the coil and still didn't get any spark.
Old Jul 22, 2002 | 09:42 PM
Mike W's Avatar
Mike W
Ignition on my 390
You might consider installing a MSD ignition. You can upgrade it later to the dash mounted timing control where you can adjust the timing while you drive.
Old Jul 22, 2002 | 10:59 PM
sparky's Avatar
sparky
Ignition on my 390
Ok where are you checking for spark?
If you are checking at the coil output and still no spark. Bad coil, bad coil output wire, lack of ground (green/yellow wire from distributor negative to ignition module), bad ignition module, to name a few possibilities.
If you have spark at the coil output and none at any sparkplugs... rotor button, distributor cap, 8 dead sparkplugs or wires
Sparky
