Sponsored by: Real Truck
Installing light bar under tailgate question.
Old Sep 21, 2005 | 06:05 PM
nightmoves2's Avatar
nightmoves2
I bought the factory light bar that mounts to the bed under the tailgate.Before I wire it to the trailer harness does anyone know if there is a factory plug on a 250?Thank's
Old Sep 21, 2005 | 06:09 PM
HeavyAssault's Avatar
HeavyAssault
The OEM connection should be found on Dual Rear Wheel trucks only, you could look around the rear wiring. You may end up just hard wiring the bar.
Old Sep 22, 2005 | 05:43 AM
mstrfxit12's Avatar
mstrfxit12
I installed a DOT bar on my 05 250 and it did not have a recepticle. I beleive I wired into the Plate light.
Old Sep 22, 2005 | 06:32 AM
Fordafied's Avatar
Fordafied
I wired mine into the license plate light wire. I cut the wire, tapped mine in and used heat shrink on the outside to protect it. Works great.
Old Sep 22, 2005 | 07:02 AM
350z's Avatar
350z
Question
My 04 f350 plugged in , no splicing , Craig.
Old Sep 22, 2005 | 09:44 AM
pumpdriver20's Avatar
pumpdriver20
If you bought the light from Ford and have not installed it yet, take it back. The light from Ford is about $45.00. I went to a place that sells truck equipment and got the same thing from them for $10.00. I hooked it up to my plate light.
BadDogKuzz
34
Apr 7, 2016 07:51 PM
93-331-29PSI
6.7L Power Stroke Diesel
15
Dec 18, 2014 05:43 PM
Magnus E
Nov 13, 2014 07:08 AM
RickBetterley
Dec 11, 2012 04:47 PM
garyc61
Mar 2, 2010 04:43 PM
