high-beams acting weird
Old Sep 20, 2005 | 07:37 PM
Jason77090's Avatar
Jason77090
hey guys, i got a question... my 97 f-150 is being weird.. the high beams are not working, when i push the blinker switch forward to lock the lights in high-beam position, the low beams turn off.. now i havent checked the bulbs themselves, although i should.. any suggestions would be GREATLY appreciated.
p.s. the fuses are fine, none of them appear to be blown/broken.
Jason
Old Sep 20, 2005 | 08:41 PM
Dealford's Avatar
Dealford
Welcome to FTE !!!
Have you tried pulling the handle back to see if the passing high beams work?
AL.
Old Sep 20, 2005 | 08:50 PM
Jason77090's Avatar
Jason77090
yep.. they dont work either.. im lost as to whats going on, but the hazards work, which i believe is part of the switch, please correct me if im wrong..
Jason
Old Sep 20, 2005 | 08:56 PM
Franklin2's Avatar
Franklin2
I would suspect the switch. You can check the bulbs, but it would be very unusual for both highbeam filaments to burn out at the same time.
Also check the plug and the wiring to the switch. They sometimes get overheated and melt.
Old Sep 20, 2005 | 08:57 PM
Jason77090's Avatar
Jason77090
all the wires look pretty decent, now for a guy who has not replaced one of these switches before, what do u think would be the best route to replace this switch?
Old Sep 20, 2005 | 09:05 PM
Franklin2's Avatar
Franklin2
It's not too easy. You have to pull the airbag, pull the steering wheel, and then you can get to the switch. Ford calls it a multi-function switch.
Old Sep 20, 2005 | 09:07 PM
Jason77090's Avatar
Jason77090
damn.. and thats the only thing stopping me from getting my new inspection sticker.. so i guess i need to start pricing getting that replaced..
Old Sep 20, 2005 | 09:09 PM
Franklin2's Avatar
Franklin2
I don't have the procedure for the 97 trucks, and they are the new style, so maybe it's not that bad. Here's the procedure for later model explorers, and they didn't have to take the steering wheel off.
http://www.autozone.com/servlet/UiBr...3d800bca6b.jsp
Old Sep 20, 2005 | 09:39 PM
Jason77090's Avatar
Jason77090
w0w.. i dont think i want to dig into that..
