02 sensor problem changed all 4 still getting codes
Old Sep 20, 2005 | 12:54 PM
dmbturbo69's Avatar
dmbturbo69
99 Expedition 5.4
just repalced all 4 o2 sensors and the light came back and says o2 bank 1 & 3 bad. any help appreciated
which one is bank 1 & 3 thanks
Old Sep 21, 2005 | 06:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 21, 2005 | 07:30 AM
ms6073's Avatar
ms6073
If you want he advice from Ford technicians, I suggest you ask your question here : Flatratetech.com
Old Sep 21, 2005 | 09:04 PM
Racerguy's Avatar
Racerguy
What were the actual codes that were received? Not just the code description please.
Usually O2 codes arent caused by the sensors themselves but by something that can cause the wrong air/fuel ratio such as a vacuum leak, dirty MAF sensor, plugged fuel filter etc.
Old Sep 21, 2005 | 09:16 PM
dmbturbo69's Avatar
dmbturbo69
Talking
I will get the codes tomorrow and let you know.
thanks
Old Sep 24, 2005 | 11:49 AM
dmbturbo69's Avatar
dmbturbo69
codes are p0171 & p0174
Old Sep 24, 2005 | 02:06 PM
Brenner's Avatar
Brenner
Not sure if its the same on the Expy as it is on the Sport Trac but I had some error codes that would have lead me to believe it was the o2 as well. I changed both of my sensors and the code was still there, I took it in to the dealer and paid my 75.00 to find out that it was a 20.00 part. There was a vacuum line from the front of the engine to the rear and the rubber elbow had a tear in it, that was the problem. It took me 5 minutes to fix.
Just a thought.
Old Sep 24, 2005 | 02:10 PM
01silvergt's Avatar
01silvergt
If you run a search on these codes you will find a number of suggestions on how to remedy the problem. Most things you will be able to do yourself.
Old Sep 24, 2005 | 04:42 PM
dmbturbo69's Avatar
dmbturbo69
thanks, they are lean codes on bank one and two.
Neibors 99 EXPY 5.4 126,xxxm
I think I'll start with the fuel filter. It still has the original
