I need a little help. i have a 2003 f250 super duty and I am interested in a 2005 Harley davidson front billet grill. Will a 2005 front grill fit on my 2003. where can i find one?
If you want to '05 grill you will need to replace the bumper. Since this is not a straight bolt-in from what I have read you will need to do a complete front end swap to get the best install. I will post a link in a minute on a install with pictures.
A 05 bumper will bolt right up on the 03. also the 05 headlights will fit too? I like the total face life can it be done under $1,000 with painted bumper?
I'm sure you could shop around and get the entire front for under $1000.
If you want a true fitting 05 front end, you need the following: bumper, grill, headlights with harness and header panel (fits behind the grill).
Options:
You can fit the headlights, but you will need to cut your stock header panel to get the fit correct.
I believe you can fit the grill, but you will need to replace the front bumper to prevent modding the new grill.
