1998 E-Superduty, no heat
Old Sep 19, 2005 | 02:54 PM
gearheadz80's Avatar
gearheadz80
I was wondering if anyone can answer why I would not be getting any heat in the cab. All the controls seem to be working fine. The temp. guage reads normal as always. There seems to be hot water in both of the heater core lines. Maybe a heater controll solonoid? If so where would it be located. The Van also has a/c that works
Old Sep 19, 2005 | 03:20 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 19, 2005 | 07:40 PM
trike1946's Avatar
trike1946
Welcome to FTE. I'm not familiar with the 98. What kind of controls do you have? Have you been running the ac and now want to switch to heat, but it still runs cold?
Old Sep 20, 2005 | 11:56 AM
gearheadz80
I'm not really sure by what you mean by what kind of controlls, but there are three turn controlls. Blower moter, temp controll, and position controll. The mornings here are starting to leave dew on the windows andits hard to get rid of without any heat, I havent used the a/c for about a month. Its not blowing cold a/c it just seems to blow luke warm air
Old Sep 20, 2005 | 01:07 PM
trike1946's Avatar
trike1946
Try checking the ***** themselves. Sometimes they wear on the back and the **** will turn but not the actual control. Turn the center **** all the way to heat. Then pull the **** off and see if you can turn it any farther with needle nose pliers. Do a search on the "blend door". That could also be a problem. I'm not sure where your solonoid is but it could also be a problem. Do you have a manual?
Old Sep 23, 2005 | 08:01 AM
gearheadz80
Well I took a look at it again today, the controls all seem to be in good workng order but it seems I have no vaccum up to the switch. The only way to open the blend door is manually or to run a different vaccum line from the engine and hook it up to the accuator. The only manual I have is a Haynes it it doesent say a whole lot especially for a deisel
Old Sep 23, 2005 | 03:58 PM
gearheadz80
Well now I went to a dealership, I have vaccum at all the acuators and the switches at the right times. The blend doors open as they should. But still no heat. Im going to try to replace the cool - warm switch tommorrow.......Any other ideas?
coxhaus
Sep 9, 2016 05:35 PM
leftfootbraker
1961 - 1963 F100 Unibody
Jan 14, 2016 06:34 PM
BMitch
Feb 27, 2015 06:43 AM
Sooper Camper
Oct 11, 2013 05:25 PM
cebru
Oct 3, 2004 05:07 PM
