1978 - 1996 Big Bronco
Good Alternator Information
Old Sep 19, 2005 | 02:52 PM
poffutt's Avatar
poffutt
Red face Good Alternator Information
I have a 89 5.8.
Every time I would turn on my AC it would pull my alternator gauge real low. Thats not suppose to happen. Yesterday I was under my bronco on the passenger side looking up into the engine compartment. I saw a ground wire that just clips on to the body and the frame. I wiggled it to see how tight it was and it moved easy. So I cleanned it up so this it could get a good ground. You know, just genneral maintenance. Well since I did that, I can run my AC now and it does not pull may gauge down but just a hair, like you would expect.
Check your grounds.
Paul
Old Sep 19, 2005 | 02:53 PM
amish77's Avatar
amish77
a clip on ground? sounds like it's time to get a soldering iron and a ring end and a bolt.
Old Sep 19, 2005 | 03:03 PM
poffutt's Avatar
poffutt
Amen to that... I to thought it looked a little chezzie, But it is a bare ground cable.
Old Sep 19, 2005 | 03:04 PM
poffutt's Avatar
poffutt
Sorry don't know how I posted this twice
Old Sep 19, 2005 | 03:06 PM
amish77's Avatar
amish77
man, I hate the way a loose ground can ruin your day, as it is right now my 77 has a couple in the dash I need to track down to get full use of the gauges at night.
Old Sep 19, 2005 | 03:08 PM
greystreak92's Avatar
greystreak92
Yeah, Ford used woven ground straps with a cleat on the end to slip over the metal edges of frame rails and portions of the body. I have put them in place and run a "tech" (self tapping metal) screw through the cleat into the frame to ensure it doesn't suffer the problem that poffutt mentioned.
Old Sep 21, 2005 | 10:08 AM
amish77's Avatar
amish77
good call greystreak, and easier than my suggestion
