Sending unit Voodoo.....
Old Sep 18, 2005 | 06:48 PM
theGman's Avatar
theGman
Am I the only one who has problems figuring out how much gas is in the tank? My gas gauge bounces all over the place. Has anyone figured out the best technique for bending the float arm to read consistently? Apparently I haven't! The truck is a '54.
The voltage is OK, the gauge and sending units are OK; the problem is more of a slo****ational issue. I'm thinking of using a stick.
This is the original tank...are new ones better baffled?
Happy trucking,
Paul
Old Sep 18, 2005 | 07:27 PM
Randy Jack's Avatar
Randy Jack
Paul -
My 56 gage does the same thing. Every time I go around a corner, the gage needle moves. Right turn - it goes to empty; left turn it'ds full again! Still, when I go straight for a while, I figure out about how much gas is really left. I really only care when I'm close to empty anyway, and I always fill around 1/4 full. I did go thru a calibration of the sender to the gage so I know it's accurate enough, but when the gas moves, so does the needle.
Old Sep 18, 2005 | 08:54 PM
imlowr2's Avatar
imlowr2
I have the same problem on my 56, not as bad as Randy's, but mine seems to bounce in quarter tank increments. I know its accurate when I fill the tank, I know how many gallons go in. It's really annoying because I'm so use to having my cars read the correct fuel level. With my truck, I know I'm somewhere between a half and 1/4 tank. Sure wish I knew what to do to fix it. I just don't look at it as much. I wonder if the needle is steady with only the ignition key on and not running?
Randy- You forgot to mention how fast you were going making those right and left turns LOL....
Old Sep 18, 2005 | 09:59 PM
Earl's Avatar
Earl
Trying to think of an easy way to make the gage average out readings over a longer period of time. With the way the originals work, a simple capacitor won't hack it. hmmmm ...
Old Sep 18, 2005 | 11:12 PM
Old-F100-Driver's Avatar
Old-F100-Driver
Hate to brake the trend but in the 45 years I have driven my F100, I have only had one problem with my fuel gauge. About a month after buying it I ran out of gas because the guage read a little above 1/8 tank, I took the sender out and adjusted it to empty. After that no problems, stays steady going around corners, actually all the time. I would guess a different sender would stop the problem.
Old Sep 19, 2005 | 07:11 PM
theGman's Avatar
theGman
Does anyone make a chrome plated stick for checking the gas level?
DR Smith
24
Jun 13, 2014 03:36 PM
paulsey
Electrical Systems/Wiring
May 30, 2014 07:45 AM
JamesHendrix
May 27, 2014 08:31 PM
OldRed4X4
Mar 29, 2007 06:15 PM
gcfisher75
Dec 11, 2002 04:33 AM
