Aerostar Ford Aerostar
Rethread or replace
Old Sep 18, 2005 | 03:31 PM
teg3's Avatar
teg3
Unhappy Rethread or replace
To make a long story short the nut on the balljoint either loosened or detached from the bolt due to its inablilty to hold in the groves.
My options are 1.get a rethread tool and rebolt this will be the cheapest.
but I question this due to its ability maintain its integrity or ?
2. just replace the whole joint and use a locking nut this time.. ?
the threads are compromised so its either replace or rethread..The balljoint is new and gave no sign of going bad just detached luck it was local and no kids in the car.
thank you
Old Sep 18, 2005 | 04:53 PM
Kruse's Avatar
Kruse
thank you
To do the job right, you need to replace the ball joint. If you get an aftermarket one, the nut should be included and it will also have a grease jerk. Then have the front end aligned and you will be better than new.
Old Sep 18, 2005 | 05:12 PM
teg3's Avatar
teg3
Any ideas why it would seperate ?to the best of my belief the nut was torked properly
carter pin ect..the allignment was done.The only thing I can think of is miss align created pressure on the bolt.
Old Sep 18, 2005 | 09:23 PM
Kruse's Avatar
Kruse
I'm not sure. Like you said, lucky to be local and no kids in vehicle.
I'm curious if the part you used was cheaply made.....
The reason I ask is that several years ago I got a couple of tie rod ends for one of my Aeros. I will not mention the brand on this group, but they were so cheaply made I was afraid to use them. I took them back and bought from another branded store. They were about half the material of the original equipment and had no zerk to them. Boots were not included.
Could be you just got a bad one from the factory and it just managed to slip through. I'm not sure about the misalignment, but I guess anything is possible.
Old Sep 19, 2005 | 07:44 AM
teg3's Avatar
teg3
it was from autozone DURAlast made in india.
