header installation
Old Jul 28, 2002 | 07:45 PM
WrenchHead84's Avatar
WrenchHead84
Post header installation
I got a '79 F-150 2WD 4-SPD, with a 302. I just bought a set of headers from summit racing. I can't get the passenger side header to fit. I pulled the starter out, but the collector from the header won't clear the bellhousing. Any suggestions will be helpful.
Thanks
WrenchHead
1979 F-150 Custom. 302 V-8 4-spd 2WD. 124,100 Miles
Old Jul 28, 2002 | 10:26 PM
jimlj's Avatar
jimlj
header installation
If the problem your having is not able to get the header past the bellhousing, try unbolting the motor mounts and jacking up the motor.
Old Jul 28, 2002 | 11:00 PM
prodigy's Avatar
prodigy
Yes I had the same problem you had when installing my 351 in my 79 F100. If you don't know a 351 and 302 are almost identical so I have the exact setup as you do. What i had to do was place the headers in the engine compartment to the side. The driver's side is pretty easy so you might not have to do it on that side. Then i had to lower the motor down and wiggle the header until i got a bolt started. Then it was basicly easy, just scoot the header around until the others line up.
Old Jul 29, 2002 | 08:47 AM
WrenchHead84
yeah, I was thinking about lifting the motor after I posted the message. How hard is it to remove/install the starter after the header has been installed on the passenger side?
WrenchHead
Old Jul 29, 2002 | 10:43 AM
rjcline's Avatar
rjcline
header installation
My headers came with instructions of flip the motor mount frame bolts around to provide more clearance...I did it and it helped. Good luck
Old Jul 29, 2002 | 01:38 PM
villagidit's Avatar
villagidit
header installation
