Warn Hub Problems
Old Sep 17, 2005 | 10:59 PM
thaichefscott's Avatar
thaichefscott
Warn Hub Problems
I have a 1995 150, 302 standard transmission(Mazda), Dana 44 front axle. I replaced the factory auto locking hubs with warn premium lockouts. Now, when I had this apart I replaced the wheel bearings however, I forgot to grease them. Two weeks later I pulled it apart again after the outer bering on the drivers side burnt up. due to the damage it caused on the hub I replaced that as well as inner and outer wheel bearings on both sides.(This time I made sure to pack the bearings.) There did not seem to be any damage to the lockout hubs so I put it back together.
Two Weeks later the lockout hub broke and when I removed the snapring on the axleshaft the inside of the warn hub shot out. I took it back and convinced the store to replace it under warranty.(well, I didn't tell them about the bearing burning up.)
Now two weeks later the hub is split apart again. Any suggestions as to why this is happening? I would like to fix this correctly. No fun when I replace the same parts over and over again.
Old Sep 19, 2005 | 07:32 PM
andym's Avatar
andym
That is strange indeed. Was there any apparent damage to the splines on the hub or the stub shaft? What about the spindle? Manual hubs are picky about being overgreased, too - are you sure you didn't put too much grease in there?
Warn hubs have a lifetime warranty - it shouldn't take much convincing to get them to return one.
Old Sep 19, 2005 | 07:55 PM
canadian 94 ford's Avatar
canadian 94 ford
I have a 1994 F150 4X4 and when I replaced my automatic hubs for warn hubs you can tighten the bolts and they still areloose. I put an extra oring in between the lock out and the hub. Did any one else have this problem?
Old Sep 24, 2005 | 07:45 AM
thaichefscott
no didn't have that problem with it being loose. well the race for the outer bearing did weld itself to the spindle. I was able to get it off and I saw just one little mark. Would that be enough to cause this type of damage. I sure don't want to spend the six hundred dollars that Ford is asking for the spindle.
Old Sep 24, 2005 | 06:23 PM
canadian 94 ford
No that shouldn't cause a problem but make sure that when you set the preload on the bearings you do it correctly. Setting them too tight will cause a big problem. Check a manaul.
Old Sep 24, 2005 | 07:56 PM
JoeVB's Avatar
JoeVB
If I remember right, the bearing nuts need to be tightened to no more than 35 ft. lbs.
Old Sep 24, 2005 | 10:57 PM
thaichefscott
the specs from warn (which they claim is from Ford/Dana) is the inner spindle nut torqued to 60 ft/lbs the backed off 1/4 turn. The outer spindle nut torqued to 160 ft/lbs. I did that on both sides. The passenger side is fine. I have had no troble with that side at all. The only trouble I have had is on the drivers side which is the side that the bearing burnt up on. After replacing the bearings and the hub assembly it self(the part that the rotor is attached to) is when the acutal lock out hubs started breaking. I can't figure it out. I think I am going to bite the bullet, claim defeat and take it to a shop. ( A shop that I know very well and wouldn't mess with me). It sucks.(with tears in my eyes) Fist time I haven't been able to fix the truck myself.
formula74
2004 - 2008 F150
May 1, 2016 07:11 PM
LADNAR
27
Mar 14, 2011 10:09 AM
BRay09
Offroad & 4x4
Feb 17, 2009 10:29 AM
lonewolf78
1978 - 1996 Big Bronco
Feb 6, 2009 03:29 PM
