Transmission Trouble
Old Sep 17, 2005 | 12:15 PM
DAYO170's Avatar
DAYO170
Angry Transmission Trouble
I Have A 1994 F150, 5.0 With A Automatic W/o.d. I'm Not Sure Which Trans I Have, The Pan Has 14 Bolts . Is It A Aode?. The Trans Acts Like Your Power Braking In 1st And Reverse. 2nd Gear Is Normal. Any Help On What Happend And Repair?
Old Sep 17, 2005 | 09:55 PM
Popa Tim's Avatar
Popa Tim
best way would be to look on your drivers door tag for the tranny code, it should be one of the two below.
Popa Tim
4R70W 1994-up trucks w/ overdrive cancel switch and P-R-N-OD-2-1 can be 4R70W tranny.
F150 door tag trans code = U . This tranny is computer controlled.
Pan length just under 15". New and improved AODE.
Wide ratio AODE w different output shaft. Avoid the version used on V6s.
E40D Built from 1989 - 1998. Found only in trucks.
Replaced C6. Electronically controlled w OD. Medium to heavy duty.
Pan is wider than it is long 20.5" X 13.5" w/ a notch out of right front corner and has 20 bolts.
Electronic OD on a 351W would be likely be this tranny. F150 door tag w/ trans code of E = E40D.
1989-93 truck with P-R-N-OD-2-1 pattern = E40D.
Non-removable bellhousing. Electronically controlled.
1994-up trucks w/ overdrive cancel switch and P-R-N-OD-2-1 can be E40D
Pan length approx. 20". Overall tranny length 37 1/2".
1995 up units are better. Older units can be updated to same level. Gets 4 or 5 thumbs up.
