Weird knock heard..
Old Sep 17, 2005 | 11:31 AM
remmers's Avatar
remmers
Weird knock heard..
I have a 89 f-150 8 ft bed 4 x 4 single cab. I just noticed that when i turn right i hear a knocking noise coming from the middle to rear of the truck, it only does it when I turn right. Any Ideas what to look for??
Thanks
Rich
Old Sep 17, 2005 | 02:45 PM
MustangGT221's Avatar
MustangGT221
Hows your bed bolts holding up? I've seen some come loose and when the truck flexes it causes a klunk...
My F-250 does it, most often when turning right into a driveway with a hump to it.
Old Sep 17, 2005 | 09:57 PM
MRL123's Avatar
MRL123
Another possibility could be the rivets that hold - or at least used to hold - your crossmember under the transimission to the frame rails. These have been known to pop out every once in a while, which of course causes the crossmember to flex and create a popping or knocking sound when turning corners.
Let us know what you find out!
Cheers!
Mike
