Speedo jumps(improper trans shift)
Old Sep 17, 2005 | 11:28 AM
guitar_god2003's Avatar
guitar_god2003
Could someone tell me what the voltage output from the speed sensor on the diff should be? I tested it while increasing speed and it only went to 5 VAC. After I got past 100klms it dropped back to 4.5 volts and the speedo jumps.
Old Sep 17, 2005 | 12:47 PM
rclarke's Avatar
rclarke
Pull the sensor out and check for physical damage. Often the ears on the friction plates in the traction lock break off and go around with the ring gear and damage the sensor. Replace it if damaged and check inside the rear end for damage. If you take the cover off check the reluctor ring for damage. Sometimes a tooth or 2 will be damaged or knocked off.
If it doesn't have physical damage check the resistance of the sensor with an ohmmeter, if its more than 1000-1500 ohms it probably is bad.
Old Sep 26, 2005 | 01:12 PM
guitar_god2003
Would you be able to tell me what the voltage should be according to speed? Does it constantly increase according to speed increase or should it back off at higher speed?
Old Sep 26, 2005 | 02:14 PM
rclarke's Avatar
rclarke
Voltage (AC) will increase with increasing speed. I don't recall the actual voltage you will get. It will not go down at higher speeds.
Old Sep 26, 2005 | 04:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
AFAIK, it is a pulse type signal so you can't read it with a voltmeter. You would have to use an oscilloscope or a frequency meter to read it.
Old Sep 27, 2005 | 08:38 AM
guitar_god2003
From what I've been told it produces an ac sine wave which should also produce an ac voltage when reading from the sensor itself. It changes to a frequency when it comes from the psom to the pcm.
