351m 4brl 4-v
Old Sep 17, 2005 | 04:29 AM
aussiesb1's Avatar
aussiesb1
351m 4brl 4-v
I have a f100 with a 351m in it.(who hasn't, right?) According to my official ford handbook it has 4-V heads and 9.1:1 compression. This is an Australian delivered vehical too. In all my research I have not seen this combination on a U.S. truck.
So what is a 4-V compared to the 2-V? and why is it on top of my motor? Is this helping to keep my compression higher?
Old Sep 17, 2005 | 07:22 AM
Torque1st's Avatar
Torque1st
Posting Legend
Why anyone, even a Ford Australia, would want to put 4V heads on a 351M is a mystery. That would be about as useless as **** on the proverbial boar hog, or for you down under, **** on a croc. Are you sure it is not a 351C? 4V heads were not available on any of the 351M/400 vehicles made in the USA.
4V heads have huge ports that are really only suitable for high RPM racing applications.
Old Sep 17, 2005 | 07:27 AM
danlee's Avatar
danlee
If it has true 4V heads it could be the 72-73 open chamber heads with 75.4cc combustion chamber.
Are you sure that it is a 351M and not a 351C. The 4v intake manifold would indeed be a rare item to fit a 351M block.
True 4V heads have larger ports and valves than 2V heads. The compression is a little higher than US 351M motors because the US 2V heads have 78.4cc chambers. You would also need a smaller dish in the piston to increase the CR.
Another possibility is 62.8cc closed chamber 4V heads with a standard 351 piston.
Again the 4V intake manifold to fit a 351M is very rare.
Old Sep 17, 2005 | 11:23 AM
grclark351's Avatar
grclark351
being in Australia it should be easy for you to find an expert on the Cleveland engine, can you get a confirmation that you absolutely do not have a Cleveland? the M engine can be easily idenitied by the height of the thermostat compared to the top of the timing cover. the Cleveland thermostsat is at the same height as the top of the timing cover section of the block. the M engine has the thermostat raised significantly from the level of the top of the timing cover section of the block, at least an inch(2.54cm) or so. most but not all M engines also have a rib of metal standing up to the right of the dizzy, about the same height as the thermostat level. there has NEVER been, not factory or aftermarket, a 4V 351M/400 intake manifold made! there are rumors of a California Police 400/4V but no one has been able to prove that a single one was ever produced. Australian intakes for the 302C/351C have the 2V port sizes internally and a 4bbl carb mounting pad, both spreadbore and squarebore. just because an Aussie intake has a 4bbl carb pad does not make it a 4V intake. what year is your truck?
Old Sep 17, 2005 | 06:42 PM
grclark351's Avatar
grclark351
i just remembered, some US 351C 4V's got over there too. if you do have a 4V engine it could be one of those?
Old Sep 17, 2005 | 08:41 PM
aussiesb1's Avatar
aussiesb1
It is an 1981 delivered f100 first registered in 1982. I am just quoting my owners manual when I call it a 4V. I would not know the difference. The thermostat is bolted on to the block just below the timing cover but by the time you get to the top of it, it is well over a inch tall. The sensors in it are almost a high a the dizzy. Also the dipstick goes into the middle of the left side of the oil pan. I have only ever seen clevelands with the dipstick going into the side of the timing cover.(or right next to it)
Old Sep 17, 2005 | 11:37 PM
Brian S's Avatar
Brian S
I've never heard of an Australian built vehicle that came with a 351M/400. A very few small port, Aussie made heads were referred to as 4V heads. It should have a 4V intake as well. They supposedly had large 4V valves with something like a 67cc chamber. My best guess is they were used when the US 4V heads were no longer available.
Old Sep 17, 2005 | 11:48 PM
witdog2020's Avatar
witdog2020
4v heads
Although I have never seen any of these on the 351m, I have a book that says they were available in Ford LTD'S. I am always looking at the yards.
I would say the key here would be F100, I would guess something like 351w, I don't think I've ever seen F100 with 351m? Not sayin they ain't available?
Old Sep 18, 2005 | 12:19 PM
grclark351's Avatar
grclark351
i just found a good pic of the front of a bare 351M/400 block. note the raised thermostat area and the rib across from it. cut and paste this item number into an Ebay search, my link didn't work, as usual. it's item # 8000868890
can you see the casting numbers down by the starter on your block? what are they?
Old Sep 18, 2005 | 12:20 PM
73XAFalcon's Avatar
73XAFalcon
If you are in Australia, and your F100 is an Aussie assembled RHD truck NOT a RHD converted US import, then your truck was Ford AU fitted with an Oz cast and built 351C. Your heads will be open chamber small port heads with a spreadbore cast iron intake and a Carter ThermoQuad carb. The 4V reference in your factory manual is referencing your carb/intake combo NOT the style of heads. Ford AU installed 302Cs and 351Cs in there assembled F100s until 1983 when the last of the Clevo engines were sold. After that, all Ford trucks sold in AU/NZ used a US drivetrain which means most had 300 I6, 302W, 351W and some 460s. The 351M/400 trucks that you find down there are imports from the US by 3rd party importers, US DoD imports, or individuals who brought them in for private use. BTW, what are the first 6 digits of your VIN? These will tell if it is a US built truck or an Oz assembled truck.
Old Sep 18, 2005 | 08:05 PM
aussiesb1's Avatar
aussiesb1
My VIN looks nothing like any US VINs I have seen. ALIJYP 80126K My engine code is C and Transmission is R. The model number is 62132. Is the aussie 351c compatable with the US 351c for things like pistons, high vol oil pumps, big stroker kits?
Old Sep 18, 2005 | 10:01 PM
73XAFalcon's Avatar
73XAFalcon
That's an Aussie VIN so I'm pretty sure yours is an Aussie built F100. That would mean your motor is a 351C OR a 302C, only way to tell is to drop the oil pan and look on the last counterweight. You will find a "302" or a "351" cast on the weight. Everything is compatable with a US 351C except the dizzy.
Old Sep 18, 2005 | 10:07 PM
grclark351's Avatar
grclark351
on the dizzy, isn't just that the Aussie block has a smaller diameter hole where the end of the dizzy shaft fits? and a US spec dizzy shaft can be turned down if the engine is to stay assembled, or the hole can be opened up if the engine is already apart? i guess this was done to keep the point dizzies out of the later model engines? for emissions reasons?
Nova406
Nov 21, 2014 08:23 AM
351Cleveland C4
13
Mar 7, 2014 06:59 PM
xlt ranger lover
Sep 22, 2006 11:52 PM
vsuccess
Nov 8, 2002 10:50 PM
xyfalcon500
May 27, 2002 01:16 PM
