Oil & Lubrication
5w-30 oil
Old Sep 16, 2005 | 04:16 PM
texas7816's Avatar
texas7816
5w-30 oil
According the owners man. my wife's 2003 explorer is supposed to take 5w-30, but due to the fact I'm lazy and I can buy Havoline 10-30 at Sam's for a pretty good price (mine dosen't carry 5-30) I've been using that. Down here in Texas it just dosen't get that cold that often, so I can't imagine I'm really doing anything wrong here, but some feedback from wiser individuals than myself would help justify my laziness. Thanks
Old Sep 16, 2005 | 08:01 PM
jschira's Avatar
jschira
You're fine.
Old Sep 16, 2005 | 08:26 PM
bigdaddyII's Avatar
bigdaddyII
Nothing to worry about.
Old Sep 17, 2005 | 12:46 AM
Big O Dave's Avatar
Big O Dave
10w-30?
Old Sep 17, 2005 | 12:49 AM
ford390gashog's Avatar
ford390gashog
it will be fine just it won't meet the 929a spec which is required for warranty. also it will have less moly and Ca. than the 5w30 havoline. chevron supreme is the same oil. and kragen sells it for 1.50 and .49 on sale.
Old Sep 17, 2005 | 07:57 AM
TallPaul's Avatar
TallPaul
How do we know this? The 10w30 also is "Energy Conserving" and being a somewhat thicker base oil, I would expect if anything it needs a little more moly than the 5w30 to meet that requirement. Calcium should be the same across the board.
Anyway, in Texas never go thinner than 10w30.
Old Sep 17, 2005 | 10:26 AM
jimandmandy's Avatar
jimandmandy
From the spec sheets, the difference in viscosity at 40C varies as much between different brands as it does between 5W-30 and 10W-30 within the same brand. Mobil 1 10W-30 for example is thinner than Mobil Clean 5000 5W-30. You are not going to notice the difference between a -20C and -25C cold cranking viscosity in Texas, and that is the only difference in the spec.
Jim
Old Sep 17, 2005 | 02:07 PM
ford390gashog
the voa on both of the oils side by side show the 5w30 has the clear advantage it has 360 ppm of moly.
Old Sep 17, 2005 | 05:51 PM
Flash's Avatar
Flash
Now TP what on earth do you mean by that? Just this last Wednesday I decided to drive the SCrew and it was showing 121F on the dash at speed. I run nothing but 5w-20 and have single digit wear metals at 5,000 OCIs. The thinner oils meeting Fords specs will have better/greater film strengths, have fewer allowable deposits, and transfer heat quicker resulting in a cooler engine. jimandmandy would be correct concerning cold flow properties for Texas. It just doesn't get cold enough here to worry about it. Minnesota, yepper, Texas- ain't happenin'.
Old Sep 17, 2005 | 07:56 PM
jschira's Avatar
jschira
Geez 'O Man!
You guys sound like residents of the old folks home sitting around and talking about their latest bowel movement.
QS, PZ, Castrol, Mobil, Exxon, Texaco, 5w-30, 10w-30. His engine is not going to know the difference.
Suggesting that it takes a NASA supercomputer to help decide whether to use Brand X 5w-30 or Havoline 10w-30 is a little overkill, don't you think? He asked a very simple question. Give him a simple answer.
Finish the paperwork, pull the chain and move on.
Old Sep 18, 2005 | 12:13 AM
TallPaul's Avatar
TallPaul
You're right. I should have qualified my statement to be directed only at those whose manuals say to run a 30 weight.
But everything is a compromise and while a thinner oil may run cooler (but not if it is too thin), it also does not pass as large of contaminant particles through the bearings and so potentially could result in higher wear metals if such contaminants are present.
If the "thinner oils meeting Fords specs will have better/greater film strengths" than say a 10w30, why is it they have lower HT/HS viscosity? Isn't that closely related to film strength?
Old Sep 18, 2005 | 05:33 AM
jschira's Avatar
jschira
Originally Posted by Earth
Earth to Texas7816, Earth to Texas7816: Use the 10w-30. Over.
Originally Posted by Texas7816
Roger that Earth. This is Texas7816 signing off.
Roger Roger. This is Earth. Over and out.
And to all a good night.
Old Sep 20, 2005 | 09:19 AM
texas7816's Avatar
texas7816
y'all kill me i swear....thats why i post here good info and a great laugh most everytime....thanks for the info, I'm gonna stick with the 10w-30 I guess
Old Sep 20, 2005 | 10:15 AM
kingfish51's Avatar
kingfish51
There would be no difference between the 5w-30 and the 10w30 in the heat. The 5w and 10w is for the cold, not the heat. That is what the 30 is. Do a search on oil viscosity.
Old Sep 20, 2005 | 05:10 PM
Flash's Avatar
Flash
Okay, so make me use my brain. Here are the numbers of the Havoline 5w-30 vs Havoline 10w-30 concerning cold pour points:
5w-30= -33F
10w-30= -31F
Not much difference and certainly within any cold temps you are going experience in Texas.
