Sponsored by: Real Truck
Power Takeoff Provision?
Old Sep 16, 2005 | 01:39 PM
Customz's Avatar
Customz
Did a search and still can't figure out what it is. Wondering if I need this option on my next company vehicle.
Old Sep 16, 2005 | 02:02 PM
CmprSpecial's Avatar
CmprSpecial
It's there to power some device.. Usually a PTO will power a winch (tow truck), air compressor, generator etc... when the vehicle is stopped.
If you have something like that, then a PTO would be nice...
Old Sep 16, 2005 | 02:19 PM
Customz's Avatar
Customz
Is it 12vdc, 120vac or something different? Powering an offroad winch might be nice and how about an air compressor for some ARB airlockers?
Old Sep 16, 2005 | 02:25 PM
CmprSpecial
From a dealership web site
A transmission-integrated PTO allows customers to mount powered accessories such as dump boxes, plow blades, liftgates, winches, skylifts, air brake compressors, auxiliary hydraulic pumps or other add-on equipment. The FORD PTO provides direct engine power for accessory equipment without the expense and installation time of separate, independently mounted electric motors or other power sources
It uses engine power to do the work...
Old Sep 16, 2005 | 02:29 PM
CmprSpecial
Here is an example of a generator mounted on a truck http://www.realacpower.com/images/realpowerweb.pdf
Old Sep 16, 2005 | 02:59 PM
3/4ER's Avatar
3/4ER
Nice set up. I wonder what's the difference in transmissions, and if it were possible to retrofit a PTO provision.
Old Sep 18, 2005 | 05:18 PM
Casey's Avatar
Casey
The difference is the hole in the side of the case and the gear inside the trans. It's possible, but expensive, to retrofit.
Old Sep 18, 2005 | 09:42 PM
Customz's Avatar
Customz
I decided to go without it.
Old Apr 19, 2006 | 03:38 PM
Mark Oomkes's Avatar
Mark Oomkes
I'm still working through all the threads, but can somebody tell me if the PTO shuts off everytime you hit the brake? This is what my upfitter is telling me and somebody at the dealership.
If this is the case, anybody have any ideas of bypassing this or reprogramming the computer? Pretty much worthless for trying to run a plow or salt spreader.
Old Apr 19, 2006 | 05:43 PM
Kep4's Avatar
Kep4
Jäger
https://www.fleet.ford.com/truckbbas/topics/f-sd.html
(You may have to type it in for it to work)
Go to 'Q-108 R1' and then page 11 for the info you need. Pressing the brake deactivates the PTO SEID for 3 seconds.
Old Apr 20, 2006 | 07:44 AM
Mark Oomkes
Thanks, it looks like the central hydraulics is going to have to work, shutting off for 3 seconds won't cut it for plowing and salting.
Old Apr 20, 2006 | 10:54 AM
CmprSpecial
The problem is when you put a link between the "[url]" things and you include the "https://" in the link, the site adds another "https://" to your link. If your link starts with "www", the link will work.
Old Apr 20, 2006 | 04:57 PM
Kep4's Avatar
Kep4
Jäger
Thanks Bill! Always good to post a link that works.
