Radiator removal
Old Sep 16, 2005 | 01:01 PM
mds79's Avatar
mds79
Radiator removal
How do I go about removing the radiator from a 96 Ranger 4.0L 5spd 4x4 with A/C?
Old Sep 16, 2005 | 01:52 PM
wresleu's Avatar
wresleu
If I remember right, it's not too difficult. Just drain it. Remove the fan shroud (only two bolts), then remove the upper and lower hoses at the radiator, then remove the tranny cooler lines (these are a bit of a pain, but be patient the threads do have an ending), then remove the bolts at the top holding the radiator, if I remember right the bottom do not have bolts, it just slides into grooves. Then slide the radiator straight up, being careful not to bank the fins.
Old Sep 16, 2005 | 01:56 PM
mds79's Avatar
mds79
Thanks for the reply....since I have a 5 spd, I wont have any tranny cooler lines, right?
Old Sep 16, 2005 | 02:51 PM
jinx102672's Avatar
jinx102672
I agree with Wresleu. It's a pretty straight forward job. I replaced mine not to long ago, '94 w/ manual tranny, and I don't have the cooler lines. As long as you have it all out you might as well replace the upper and lower hoses to the radiator, unless you've done so recently.
mtnxtreme
Apr 6, 2016 10:06 AM
kupiec20
Jan 19, 2015 11:05 AM
