Well, it's really more of an FE446 associated transmission update.
I was diggin' around under there trying to find out where/why this transmission likes to mark it's territory with tranny fluid wherever I go.
Then I noticed that the vacuum flux inducticator gizmo was loose and looks to be where a thick congregation of fluid was. I figure this is A) one if not all of the leak and 2) might induce bubblification within the fluid that was causing some venting I had seen (of course, it might have been too full). Ever notice that a standard wrench will not fit on the 3/4" nut that tightens the gizmo. Need a skinny wrench to tighten that thing. Or, I'm missing some parts.
Anyway, if I ever get motivated, I'll get it all back together, top off the fluid and see what happens. I'm also ordering a B&M shift kit from Summit. Looks like they offer a basic C6 shift kit for about $30. For some reason, my kick-down linkage doesn't look right since the last transmission reinstall and ratchet shifter install???? Do, I really need the kickdown if I have a ratchet shifter?
The kickdown will allow you to leave the shifter alone when you hit passing gear goin' by some ricer. Otherwise you will need to manually move the shifter to get that.
I understand that. But, now it's much easier and more fun for me to manually kick it down anyway (Slap 1, Slap 2...why is the back of the truck coming around now??...oops). Does the kickdown do anything else for the performance of the transmission? I'll get it right eventually, but is it going to do anything for me at the track?
It doesnt meen crap Greg!! if you dont mind shifting!! As much HP and TQ as that thing has you probably dont need a lower gear to get around someone anyway!! LOL.
And if that gizmo your talking about is the Vacuum modulator? and your sucking air into the case, that could be a cause of it foaming up and coming out of the trans..But I dont think thats it..it maybe where your leak is at.. But if it is sucking air and all Vacuum is not directed just too the modulator..your trans will shift funky and slip!!
I remember years ago I got a Mooch deal on a 63 Impala SS... that was cherry!! the guys was selling it because the Chev Dealer told him the motor was shot..(it was smoking) he didnt want to invest $4000 for the dealer to install a new engine..So I bought it from him for $500..brought it home..put a new Modulator in it!! and No more engine smoke!! I loved that ride... 327 and a 4 spud!! Then The Lowrider's in the hood thought they would barrow it..and not give it back!! LOL..Oh well, thats one reason I dont live in Cal anymore!!
If the modulator is loose it will leak, but won't cause air to be sucked into the tranny. This part doesn't "suck", it gets sucked on (by manifold vacuum). The problems occur when the inner diaphragm ruptures and tranny fluid starts getting ingested by the engine (like Russ said).
I like having the kickdown working when I'm just driving around town. It's nice not to have to worry about the downshift if you've got a coffee mug in your hand (or some other beverage). I also had problems with my linkage after the B&M shifter install. I ended up making a new kickdown lever. I think I mentioned that in a PM I sent to you a while back.
Nope, it's not an AOD, so that kickdown doesn't modulate anything - except kickdown
If you do leave it off, tie-wrap it whichever way is "no pedal" - my friend left one hanging one time and couldn't figure out why it would downshift when he went over bumps...
good point! although, mine doesn't seem to move that freely...
tranny might still be leaking, or that might just be some spliiage from filling it up.
I got the truck back to running and the exhuast cut-outs are working again. It sounds great :-)
I'll be ordering a shift kit soon. If I can get the leaks resolved this thing ought to be in pretty good shape. Since the last track trip, I've fixed a lot of the gremlins (fan controller etc.). I think a track trip is soon to happen. Hopefully we'll get some cooler weather soon and we'll see that 13 second timeslip for the 1st time
I usually run 93. And sometimes I'll get 100 when at the track.
I don't think it's HP keeping me out of the 13s. I gotta get it to run consistently, get some traction (use the sticky tires, and avoid wheel-hop) and not have various gremlins show up like last time. Every pass we made on the last trip we had to fix something else that came loose or leaked or just quit.
I think I've just about fixed most of those issues and it's running much better and more consistently. There's still some carb tuning to do. But, I might save that for the track when Strokster can help and we can see the results.
Greg, when you do the shift kit I would recommend installing a "R" code servo as well; the "R" comes from its original installation in the 428CJ C6s. The servo handles the intermediate band pressure and the "R" code version applies more pressure, making the shift more crisp. The intermediate band is your second gear, which makes or breaks you at the track. Changing out the servo is a bolt-in deal.
