Brighter Brites
Old Sep 15, 2005 | 08:57 PM
Tech 1's Avatar
Tech 1
Post Brighter Brites
I just did the headlight conversion to work off of relays as described in the tech article by Steve Delanty. Wow what a difference. I also put in the Hella H-4 conversion . Guys this is the way to go with your lights. The difference is amazing.
Old Sep 17, 2005 | 10:42 AM
heep70's Avatar
heep70
Watch out the Hellas will crack if you tighten them to much. It won't happen tell you run the lamps for awhile. I have had two of the crack so far. They won't replace them either. They will say it is caused from thermal impact. Also, do not put any protective covering on them. They will blame that also. Good luck
Old Sep 17, 2005 | 11:51 AM
Tech 1's Avatar
Tech 1
Thanks for the heads up.
Chucktown
Jul 11, 2016 04:23 PM
MET-TECH
Mar 22, 2016 03:05 PM
WhatsAChevy?
Dec 20, 2015 12:58 PM
RM2738
6.4L Power Stroke Diesel
Jun 25, 2013 11:28 PM
Andy63
Jun 9, 2002 01:18 PM
