chip setting
Old Sep 15, 2005 | 07:16 PM
gatorpsd's Avatar
gatorpsd
chip setting
Just wonder what setting yall run 90% of the time . I run 90hp. Not sure if that is good or bad
Old Sep 15, 2005 | 07:29 PM
lukecline's Avatar
lukecline
I run my custom light tow/ econo program (~325-350 rwhp) most of the time.
luke
Old Sep 15, 2005 | 07:31 PM
Fordafied's Avatar
Fordafied
Right now I am running in my custom "extreme" setting. (new chip). Before I was running in the 100 hp setting 100% of the time.
Old Sep 15, 2005 | 07:55 PM
Craig64's Avatar
Craig64
I've only had my chip a week, but I've been running in economy (60 hp) mode most of the time.
I've put in in extreme (125 hp) mode a couple of times, but the tires are too noisy in that mode.
Old Sep 15, 2005 | 08:05 PM
wlihntr's Avatar
wlihntr
most of time i run mine in the stock setting
Old Sep 15, 2005 | 08:18 PM
bigdaddyTank's Avatar
bigdaddyTank
I was running 70hp most of the time but an now running the 100hp setting to see how mileage does. Gotta quit makin smoke though
Old Sep 16, 2005 | 10:48 AM
dantran's Avatar
dantran
I have a 34' Cedar Creek that weighs in at over 15,000 pounds. I pulled it over 2200 miles with the 110HP programmed in. No problems at all. The higghest I ever saw the Pyro go to was a bit over 700 degrees F. It pulls that thing like it is not even there. (Not that I would recommend it but I had no problems doing 80MPH on the highways.)
I think you are fine. Just watch the Pyro.
Old Sep 16, 2005 | 11:25 AM
wycowboy's Avatar
wycowboy
Hey dantran,
those have got to be post turbo temps right?? I'm stock and not pulling I can get to 1200 easy pre turbo temps.
If you are post turbo you have got to add ad much as 300 degs to get you actule temp which puts you at 1000 still great considering the setting your running in!!
Traveling Man
6.7L Power Stroke Diesel
Jan 30, 2017 10:39 AM
Apocalypse
Feb 8, 2016 08:49 PM
Pitweiller13
Paint & Bodywork
Jan 11, 2016 01:55 PM
CougarJohn
Apr 16, 2015 06:27 PM
bigcountry1009
Oct 24, 2014 07:59 PM
