Intermitent wipers
Old Sep 15, 2005 | 02:56 PM
bonechief's Avatar
bonechief
Intermitent wipers
My truck has lo or high speed wipers no intermitent...Can i just change out the switch with an intermitent or do i have to change the motor to...Any body know......
Old Sep 15, 2005 | 02:58 PM
RR4E's Avatar
RR4E
You'll need the switch and delay box, as well as the wiring harness for both from a donor truck. The motor itself isn't required.
Old Sep 15, 2005 | 04:27 PM
hermangarza's Avatar
hermangarza
do they sell it at an auto part store?
Old Sep 15, 2005 | 05:25 PM
ClydeSDale's Avatar
ClydeSDale
Your best shot is a salvage yard, especially one that will let you pull your own parts. That way you can see exactly how it should be "transplanted" in. I did it with Clyde and love my intermittant wipers.
Old Sep 15, 2005 | 08:50 PM
truckfarmingcanuck's Avatar
truckfarmingcanuck
This is a gratifying upgrade. My advice is to be patient when you find one at the bone yard. The little delay box is about 4" square and attached to the switch by wires that are about 9" long. It will be fairly well hiden. The switch comes out easy and the box should as well but they bolt it in a spot your hand doesn't fit go so you may end up doing cab gymnastics to get yourself in a position to see the box and it's fastener...
Good luck
Old Dec 1, 2010 | 09:26 AM
mcwbyu82's Avatar
mcwbyu82
Old thread I know but a very good one.
Can anyone post what years/vehicles can be used for a direct swap of switch and delay box to my 1982 F150.
Thanks
Old Dec 1, 2010 | 09:27 AM
6fifty_f1fifty's Avatar
6fifty_f1fifty
um, probably 80-86...
Old Dec 1, 2010 | 12:33 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
1980-1983 F-100
1980-1991 F-150/F-350 and U-150 Bronco
1980-1999 F-600/F-900
Have compatible switches and wiper govenor boxes if equipped. The 1987 and newer govenor boxes are redesigned and look different but work the same and are used as a Ford service part for all the models listed above when you buy a new one from the dealer.
The wire harness extention is a part of the wiper govenor, and will plug between the trucks wiring and the switch. No wiring required. No need of a different motor.
All you need is the intermittant wiper switch, and the wiper control govenor. Plug and play.
Old Dec 1, 2010 | 12:43 PM
mcwbyu82's Avatar
mcwbyu82
Thanks guys. Just what I needed.
Oh and is there a quick way to recognize one? Different markings or do i just have to try to turn it to the left?
Old Dec 1, 2010 | 01:19 PM
Greyf100's Avatar
Greyf100
i have an extra i ned to get rid of...shoot me a PM or Email
Old Dec 1, 2010 | 02:23 PM
81-F-150-Explorer
Turn it to the left is the easiest way.
Old Dec 1, 2010 | 03:09 PM
Grubbworm's Avatar
Grubbworm
If he doesn't take it, I might. Just let me know, and I'll pm you.
Old Dec 1, 2010 | 03:12 PM
glovemeister's Avatar
glovemeister
I''ll jump in third here on the IWS.
Old Dec 9, 2010 | 04:31 PM
pengintamer's Avatar
pengintamer
Just picked up these parts from a local junkyard. $40. They pulled the parts for me. Super excited to install em!
Old Dec 9, 2010 | 04:39 PM
Rogue_Wulff's Avatar
Rogue_Wulff
There's one item not mentioned. There's an extra wire (seen in the above pic) that must be grounded for the intermittant feature to work. Best place to ground it, is the screws that hold the governor to the dash.
I dunno why ford didn't just make that wire ground internally, would have been easier.....
