Modular V10 (6.8l)
gear change
Old Sep 15, 2005 | 08:44 AM
superduty lee's Avatar
superduty lee
gear change
I have an 02 crew cab short bed 4x4 with 3.73 rear end , 5" lift with 35" tires and pull a loaded toy hauler that weighs about 8500 lbs . I was going to change to 4.30 rear end but the shop i want to do it says i should go to 4.56 , does anyone have any input on this change. I have also thought about removing my lift and going back to stock tires ,but i do like the way the truck looks .
Old Sep 15, 2005 | 09:41 AM
ken04's Avatar
ken04
makes sense, your tires are nearly 20% larger in diameter than the stock size so a 20% gear tooth increase puts you at 4.47-1 to maintain your 3.73 ratio. I may even go a tad lower (numerically higher) to give yourself a 4.10 ratio. If you like the look of 35's, and who doesn't, the gear swap is the only realistic way to restore power and save wear and tear on your running gear. Towing 8500 lbs of trailer with 3.0-1 gears is going to beat your drive line parts to death. I know first hand after I saw my brother replace 2 trannies, a carrier bearing set and pinion bearings in his 4.10 geared F350 with 38"s.
Old Sep 15, 2005 | 09:49 AM
2000silverbullet's Avatar
2000silverbullet
I guess we'll see how long my 3.73's last me with my 37's then. ha ha. Going on 3 years now with 'em and I can't even remember what it's like to have the truck the way it used to be. I figure as long as I still get my BSEG's, I'll be ok. Unlike the most of you that might get your BSEG's from the speed of the V10, mine comes from the grunt of driving over things.
As for the initial question, I'd go with 4.10's (4.30's at most) so you can still get some decent gas mileage on the highway when empty. My .02.
Old Sep 15, 2005 | 01:38 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Let's put it this way:
The Superduty ('04 and earlier) in stock trim is good for towing up to 12,500 lbs with STOCK-sized tires and 4.30 gears. With 3.73 gears, that drops to around 10,300 or so, depending on the empty weight of your rig. In reality, 3.73's are good for about 8000 or so, MAYBE in real-world driving.
So, you have 8500 lbs, 3.73 gears and tires that are 4" taller than stock (mine are just shy of 31"). The taller tires take away 13% of the torque reaching the ground compared to the stock 31" tires.
Going from 3.73 to 4.30 is a 15% INCREASE in torque to the ground, so 4.30's will bring you back close to what your truck was putting down stock w/3.73's.
4.56 is 6% better than 4.30's.
So, what I'm trying to say is, a 3.73 geared truck with stock tires pulling 8500 lbs is "OK". With 4.30's, and stock tires, it's much better (according to many here).
If, with 35" tires, you want the performance other people get with 4.30's and stock tires, you need 4.88's.
4.56's are a good compromise, being right inbetween the performance of 3.73 and 4.30 gears, using your 35" tires.
Does that make sense?
art k.
Old Sep 15, 2005 | 10:04 PM
BFR250SD's Avatar
BFR250SD
I'm running about the same setup. Get the 4.56's. That will take into account the additional rotating mass of the tires as well as the size. Pulling the trailer, you'll be glad you did.
Old Sep 16, 2005 | 09:14 AM
ken04's Avatar
ken04
Originally Posted by krewat
So, what I'm trying to say is, a 3.73 geared truck with stock tires pulling 8500 lbs is "OK". With 4.30's, and stock tires, it's much better (according to many here).art k.
Agreed, at somewhere around this weight, I tow OK, at around 10K it's more of a struggle. I don't mind rpm's when I'm towing but it's not so good for gas mileage. 4.10's or 4.30's would put my rpm's in the peak hp/torque range for towing that I do not have with the 3.73's. But with up to 8K it's not that big of a deal plus the lighter weight overall of my 5200 lb rig helps. I even dropped a tire size to put my effective gear ratio around 3.95-ish which makes a significant difference with a heavy load. The 4.30's would be so much better.
Old Sep 16, 2005 | 10:56 AM
krewat's Avatar
krewat
You've got a Dana 60, don't you?
Also, remember, the E's have a smaller diameter tire than the SD's anyway ... Ken, what size is stock on your E ???
Old Sep 19, 2005 | 09:21 AM
ken04's Avatar
ken04
Yea, Dana 60 and stock tires on the newer vans were 245/75/16. I went with 225's, E-rated RVT truck-type tread on the rear and a little different tread for the front for better steering and braking.
We're slowly climbing out of the hole our family fell in through 4 1/2 yrs of being sick and the 9 surgeries. Then I'll begin again with my plans to drop the beast 4" in front and 6" in the rear and hot rod it up a bit.
Old Sep 19, 2005 | 09:51 AM
krewat's Avatar
krewat
That's just not right.
There's something wrong with a V10 going DOWN instead of UP. Oh wait, I forgot you have an E
