signallite switch,tiltsteering.
Old Jul 20, 2002 | 09:51 PM
fordguy76's Avatar
fordguy76
Old Aug 3, 2002 | 05:16 PM
pranksterf150custom's Avatar
pranksterf150custom
micheal t.hi, all,my problem involves my tilt steering, the signallite switch,hazardlites.the signals work,but dont click off after turning,left or right.hazardlites dont work at all.also tilt wheel sticks,any ideas about finding wiring harness/switch for under 300.cdn??? all help welcome thanks mike hey that was easy, and no nasty words either,although i was tempted...
Old Aug 3, 2002 | 06:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks for holding your tongue:-)
The best place for these types of parts are a local salvage yard, pull the parts you need. You could consider getting a whole column assy.
Old Aug 4, 2002 | 01:21 PM
pranksterf150custom
micheal t.hi,me again,were there alot of options on these older trucks.i was a bit surprised when i found mine had tilt,reason i bought it,and it had a 302.is it reasonable to put a steering column from a newer truck,such as a 1980 to 1982??i think some of them came cruise control(the 73 to 79,s i mean.)i will check the salvage yards as you said thanks for your input. mike
Old Aug 4, 2002 | 07:57 PM
thitdog's Avatar
thitdog
I swapped in fuel injection and aod from an 86 and was very tempted to swap in the tilt column with cruise. Alas I thought it was going to be too much of an engineering feat for me to acomplish on something as important as my steering. If you have your engine out and have some spare time I'm sure it could be done. You would either need to do some splicing and conect your ignition wires to the ignition switch in the new column(which would be nice for the locked wheeel) or you need to leave it be and just use you orginal. The main differece is the mounting under the dash and the way the coupler connects to the steering box in the engine bay. It was tempting but it would have been a lot of work, I will just keep looking for a tilt that will fit in directly:-)
Lee
Old Aug 4, 2002 | 09:00 PM
pranksterf150custom
micheal t.i like the idea of leaving it original,less work for one thing.i think ill just look for a tilt system in my size.thanks again mike
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
