motor mounts
Old Sep 14, 2005 | 02:28 PM
detmerdj's Avatar
detmerdj
motor mounts
im gettin ready to drop in a 460 in my truck that haas a 400m in it what kind of motor mounts do i need and how much $ do they run
Old Sep 14, 2005 | 03:30 PM
thesprocket26's Avatar
thesprocket26
What year of truck? If it is a 73-79 any motor mounts from one of these year trucks will swap over. You can find them at online auctions or LMC and L&L productions sells them new.
Old Sep 21, 2005 | 12:57 AM
mike 77jadegreen's Avatar
mike 77jadegreen
you need mounts from 460
Old Sep 21, 2005 | 05:32 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Mike 77jadegreen, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 21, 2005 | 12:47 PM
77460f150's Avatar
77460f150
I used L&L in one of my swap's, try Jeff's Bronco Grave yard, should be around $125 for a set. You could try L&L direct also (out of Texas). I used performance unlimited mounts on the second swap I did, also around $125 a set. Try a web search for "Performance Unlimited". With these mounts you will have to have the engine out to be able to redrill the holes in the engine stands, they need to be 2" forward from OEM location. Full instructions are provided with new mounts. I have never had a motor mount failure with either brand, and these trucks are not light duty use vehicles with me behind the wheel. -Ed
PS- I am assuming that your truck is an F-150 4X4, if not this is NOT the correct info for a 2WD. If it's a 2WD just get stock mounts from LMC or local auto part's store.
Old Sep 21, 2005 | 02:23 PM
detmerdj's Avatar
detmerdj
its i a '77 4x4 f 250 and what about the oil pan currently its a front sump but it looks like it will clear the frame and axle
Old Sep 21, 2005 | 08:29 PM
slowring's Avatar
slowring
no you need to find a rear sump oil pan
