Fuel Pump Cam - 460
Old Aug 5, 2002 | 09:36 AM
jcs17's Avatar
jcs17
Fuel Pump Cam - 460
Hi, i had a questin about the fuel pump cam on the cam of a 460. The truck i have has a new motor, which was installed by the person who owned the truck before myself. I put a new fule pump on the truck the other day and i reached in the opening and noticed that the fuel pump cam turned freely. The last 460 i had taken apart, i could have sworn the cam was solidly mounted. Could this truck have bearings on the cam??? I'm slightly worried that soemthing is loose. Thanks for any help.
Jared Schoenly
78 F-100 Shortbed
460 C-6
Old Aug 5, 2002 | 09:43 AM
Mil1ion's Avatar
Mil1ion
Fuel Pump Cam - 460
Was that for sure the cam lobe or maybe it was the oil slinger ?
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Aug 5, 2002 | 02:57 PM
f100dw's Avatar
f100dw
Fuel Pump Cam - 460
It has been a while since I worked on a stock 460, but I think the fuel pump cam is two pieces. The inner part bolts down with the cam bolt and the outer sleeve is free to spin on the inner part.:-)
Old Aug 5, 2002 | 03:53 PM
Big Bad 1Ton's Avatar
Big Bad 1Ton
Fuel Pump Cam - 460
i will pull the cover off of the 429 tonight and post my findings later
Old Aug 6, 2002 | 09:03 AM
Big Bad 1Ton
Fuel Pump Cam - 460
The fuel pump ecentric is bolted to the front of the cam and should not move. if what you are feeling is staying in the same place when you spin it then there are no worries with the ecentric
Old Aug 7, 2002 | 10:41 AM
78bigunns's Avatar
78bigunns
Fuel Pump Cam - 460
Hey. Just did a timing chain and gears, my eccentric bolted to the cam, and then had a outer piece that spun freely that goes against the fuel pump's arm. (I don't know the proper for the "arm") My 460 is stock also. Maybe this will help. Good luck, Blair
Old Aug 7, 2002 | 10:46 AM
BB's Avatar
BB
Fuel Pump Cam - 460
78bigunns
15
Feb 5, 2015 03:59 PM
Jrod Webb
25
Oct 29, 2013 08:24 PM
77_150_460
Jun 22, 2010 12:08 PM
mikem78
13
Jul 29, 2004 05:04 AM
psualumnut
Aug 4, 2002 08:33 PM
