59 f-100/250 4x4 speedometer cable??
my cable broke, and I called up Sac Vin Ford, looking for speedo. They said it mounts in back of the transmission and goes up to the gauge. However, in my 4x4 it hooks in the back of the transfer case, and is 25 inches longer than the approx 75 inches that thier factory replacement is. They don't list one for the 4x4......anyone know where to get a replacement cable at a reasonable price. otherwise I need to get one custom made. also I pulled mine out of the housing, each end isent, which side has the collar on the cable, both ends screw in, but are different sized threads.
thanks Marc
thanks Marc
on
Marc,
Check with NAPA. They have a universal speedometer cable that you cut to length. They also have a universal speedometer housing if you need one. I'm not sure what the length is, but it's worth checking out. I have used their universal cable in several older vehicles and it may work for your 4x4.
Vern
Vern
wpnaes
S. California Chapter
50
07-31-2016 08:59 PM
MARC
03-30-2016 11:59 AM
MARC
12-15-2015 09:46 AM
