radiator change
Old Sep 13, 2005 | 12:07 PM
olered53's Avatar
olered53
Question radiator change
what radiator has most of you guys been using i have a 53 with 289 that will have air motor is stock other than 470 lift cam dont really wont to pay 600.00 for one from griffin or walker or will the stock one keep me cool it was for a 215 six banger.
Old Sep 13, 2005 | 12:13 PM
Randy Jack's Avatar
Randy Jack
Your stock radiator should be fine. I run a cammed 351C with a stock radiator and it is plenty. Your 289 won't produce heat much different from the stock motor and less than my motor.
Get your stock radiator boiled out and pressure tested at a local shop. You should be fine. If your stock radiator is shot, look at recoring it or buying a replacement stocker. Those will be the least expensive options.
Now, if you want to add "bling" to the underhood look (aluminum, double cross-flow, etc), the sky is the limit on cost, but it will be pretty!
Old Sep 13, 2005 | 12:37 PM
olered53's Avatar
olered53
thanks randy im not in to all the chrome,aluminum etc under the hood olered will be driven and i mean driven as a daily driver.
Old Sep 13, 2005 | 12:41 PM
Jag Red 54's Avatar
Jag Red 54
I run a 289 with A/C in my 54. I bought the super-stock rad from Mid-fifty. It has larger tubes than stock and still appears stock. Works great for about $400. Good luck, Jag
Pappys53
21
Nov 12, 2010 12:16 PM
Aussie 53
Mar 27, 2008 03:55 AM
Innovative Detailing
Nov 20, 2006 11:10 AM
PirateGhost
Sep 3, 2004 09:48 PM
