Radiator question
Old Nov 9, 2010 | 02:39 PM
Pappys53's Avatar
Pappys53
Radiator question
I want to repace the radiator that is in my 53 truck. Is not a stock radiator and the way it was put in is ugly. I have a 350 small block in the truck right now. I was wondering if a stock radiator would be good enought to keep it cool or do I need an aftermarket one? Are aluminum radiators any better then the copper and brass ones?
Old Nov 9, 2010 | 02:54 PM
Old F1's Avatar
Old F1
I would think that even the stock one would have to be modified to fit the small block.
Lots of previous post about dodge pick up rads being a bolt in.
Have a look at the mid-fifties web site / catalog?
(no) but now you have started it!!!
Old Nov 9, 2010 | 04:17 PM
jim collins's Avatar
jim collins
Yeah, it's been awhile since we had this arg.... I mean discussion about ,copper,brass,and aluminium radiators. I like copper brass. Allthough the aluminium ones are purty
Old Nov 9, 2010 | 04:35 PM
Jag Red 54's Avatar
Jag Red 54
I think either alum or copper will work. However, depending on where you drive, you may need a three core. Most important is air flow during bumper- to-bumper driving. An electric fan will prob be a good investment over the stock fan unless you have a shroud and it sounds like your current setup is without. I would buy a stock unit from Sac Vintage Ford and put their electric fan/shroud combo on it. Good luck, Jag
Old Nov 9, 2010 | 08:16 PM
GreatNorthWoods's Avatar
GreatNorthWoods
The mid-70s Dodge pickup D-200 radiator fits well especially for a SBC since the outlets are in the right place. Get one for a 5.8 V8 with A/C and it will be a three row. It comes with a U shaped bracket on the side. Saw off the leading or trailing edge of the U and drill a few holes and you are good to go. )
Old Nov 9, 2010 | 08:30 PM
55 f350's Avatar
55 f350
dont know about the inlet / outlet locations , but lets not forget that the 67-79 ford truck radiators are almost a direct bolt in too . i think you have to drill two new mounting holes if i remember .......................
Old Nov 10, 2010 | 09:24 AM
AmericanROCKBREAD!'s Avatar
AmericanROCKBREAD!
Just Checking - True for '56? - What's the best donor?
The OP has a '53 - will these same year radiators (67-79 ford truck radiators) fit my '56? I assume yes, but wanted to check.
Are the F-250 different than the F-100 for donor trucks? - Are there preferred radiators to get - such as a different amount of cores, or if the donor has A.C., Etc?
<O
Thanks, Joe<O
Old Nov 10, 2010 | 09:49 AM
whateg01's Avatar
whateg01
Originally Posted by AmericanROCKBREAD!
Are there preferred radiators to get - such as a different amount of cores, or if the donor has A.C., Etc. ...
Thanks, Joe<O
That will depend on the application. In general the more rows, the better, though there is a point of diminishing returns. Bigger motors require more cooling capacity, as well.
Dave
Old Nov 10, 2010 | 09:59 AM
GreatNorthWoods
Dave
So true! I will never have another four core radiator. They are too hard to get air through. Stay with a three row for the best compromise...
Old Nov 10, 2010 | 11:25 AM
DR Smith's Avatar
DR Smith
Rad.
In June I bought a new alum radiator.From AFCO racing products. $417.86 it is a bolt in and you can have them put inlet and outlets on either side. It keeps my mild 351 winsor running cool.
Old Nov 10, 2010 | 09:09 PM
calorchard's Avatar
calorchard
Mine is out of a 72 Plymouth Satellite with a mid 60s Chevy truck shroud. Good for my 305.
<a href="http://s125.photobucket.com/albums/p74/calorchard/f100/?action=view&current=PICT0023-1.jpg" target="_blank"><img src="http://i125.photobucket.com/albums/p74/calorchard/f100/PICT0023-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://s125.photobucket.com/albums/p74/calorchard/f100/?action=view&current=PICT0039.jpg" target="_blank"><img src="http://i125.photobucket.com/albums/p74/calorchard/f100/PICT0039.jpg" border="0" alt="Photobucket"></a>
<a href="http://s125.photobucket.com/albums/p74/calorchard/f100/?action=view&current=PICT0006.jpg" target="_blank"><img src="http://i125.photobucket.com/albums/p74/calorchard/f100/PICT0006.jpg" border="0" alt="Photobucket"></a>
Old Nov 10, 2010 | 09:43 PM
carnut122's Avatar
carnut122
Any input on a radiator for a 53 with a 302 SBF in it?
Old Nov 10, 2010 | 10:46 PM
Lakotas53's Avatar
Lakotas53
I have a 53 with a 351W and I bought a 75 dodge radiator and it fit great. I had to open up 1 hole on top and drill 2 new ones on bottom. I also had a radiator shop relocate the inlet and outlet ($50.00). Can't say how it will cool yet as I'm not quite ready to start the motor.
Old Nov 11, 2010 | 09:46 AM
52 Merc's Avatar
52 Merc
The only benefit to using aluminum over copper/brass is weight savings. Copper will dissipate heat better than aluminum, all things being equal. The benefit to using a stock-style radiator is all your original shrouding will fit correctly to direct the airflow through the core. You will need to do some fabrication for air blockage if you choose a different rad, and if you want it to be efficient. Aftermarket, stock-style radiators are available in any water neck location you desire. And they also work with pressure caps, too, if you choose the right one. It all depends on the look you desire and how much work you want to do.
Old Nov 11, 2010 | 10:59 AM
BBKtech2's Avatar
BBKtech2
I'm a purist. Stock radiator. I think it was Griffin that has an aluminum version of the stock radiator. Looks great. Copper is just fine though. Above all else, it has to have a shroud on it to perform at it's best. 16 -18" fan.
