Spark plug Question which ones NEED HELP
Old Sep 13, 2005 | 10:26 AM
triplepower's Avatar
triplepower
I have a 91 250 4x4 with a 351 I pulled the plugs and they are champion-RN9YC4 and the book call for champion RV15YC. I just bought the truck and the plugs that were in it(rn9yc) are much bigger around and the threads are like a quarter in longer. Does anyone have any insight, should I just put the new ones in. They just look so much different in thickness and length.
Old Sep 13, 2005 | 11:06 AM
triplepower
ok i went on champions web site, and answered my own question, the ones that were in there won't even fit a ford. I don't know what dumb *** put them in. No what do you think putting the new ones in will do for my motor????????
Old Sep 13, 2005 | 12:27 PM
triplepower
got it all back together and it is missing all over the place!!!!! I got a haynes manual and I think I got the wiring right to the distributer no I'm at a loss!!!!!
All I did was plugs wires cap and rotor
Old Sep 13, 2005 | 08:11 PM
TigerDan's Avatar
TigerDan
If you're positive the wiring is correct, pull the plugs and have a look at them. See if they are still gapped correctly. If not, if the gap has closed up, then the plugs are not correct and maybe someone changed the heads. I don't really see it since you describe the old plugs as being longer, but I suppose it's possible.
If all looks okay, then test each plug, you may be suffering from Champion Syndrome. I have seen brand-new Champions dead right out of the box. I had 3 in the same set one time, truck only ran on 5 cylinders till I put the old plugs back in. Switched brands, problem solved.
Old Sep 13, 2005 | 08:53 PM
Holmesuser01's Avatar
Holmesuser01
Smile
I'd buy a set of Autolites for it. Champions are for Chryslers.
Old Sep 14, 2005 | 08:27 AM
triplepower
cyl. 8 plug was smashed, my mistake. Thanks for the help. Still can't figure out why they put the wrong plugs in but oh well
Old Sep 14, 2005 | 09:06 AM
TigerDan's Avatar
TigerDan
Did you smash it closed by accident when installing it, or is there an interference problem? Put it back and see if the incident re-occurs.
Tedster9
Mar 12, 2017 09:01 AM
EpicCowlick
All Things Towing
Jan 25, 2017 10:59 PM
EpicCowlick
Jan 19, 2017 08:23 PM
Torrance00
22
Aug 30, 2016 01:48 PM
yellott
Oct 18, 2006 08:20 AM
