75 Highboy
Old Aug 4, 2002 | 02:20 PM
Gunhunter21's Avatar
Gunhunter21
75 Highboy
I just looked at a F-250. The owner claims it to be a 75, but has a 79 front grill and headlights. Are these interchangeable?
Also it has a flat bed on it. The bed is on wood blocks to clear the frame. The frame is higher above the axle, but drops to the rear and towards the cab. Is this also normal?
Any help is appreciated.
Old Aug 4, 2002 | 03:11 PM
fatdaddy's Avatar
fatdaddy
75 Highboy
Is the xfer case mounted behind the tranny with a drive shaft connecting the two and does it have conventional power steering or does it have the power assist type system, where the pitman arm is connected to a control arm\valve with 4 separate hydraulic lines connected to a ps pump and a slave cylinder mounted on the frontaxle-----people interchange front grills all the time so i wouldn't pay much attention to that------------ford moved the xfer case UP and mated it to the tranny in midyear 77 and converted the ps system to a regular type system in mid 77 as well...,fd
Old Aug 8, 2002 | 08:36 PM
Fordman54703's Avatar
Fordman54703
75 Highboy
Old Aug 8, 2002 | 11:03 PM
militaryoz's Avatar
militaryoz
75 Highboy
for the most part, 73-79 F150-250's are interchangeable, this goes for grill, fenders, doors, gauge cluster, etc. If anybody says otherwise, they can come down here, look at a 77 f250, and then look at the 2 F150's we used for parts
Old Aug 9, 2002 | 08:45 AM
Big Bad 1Ton's Avatar
Big Bad 1Ton
75 Highboy
hey Militaryoz you forgot F-350's
Old May 15, 2004 | 12:19 PM
ldbranda's Avatar
ldbranda
nice
sounds good to me
Old May 15, 2004 | 03:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
There is a post re "Highboy" in the FAQ sticky at the top of the forum.
Old May 15, 2004 | 05:15 PM
ivanribic's Avatar
ivanribic
Holy ancient artifact! This was from a couple years ago!
Goliath1975
24
Oct 23, 2014 10:15 PM
rpharesjr
Aug 9, 2012 03:03 PM
johndeere75
Mar 27, 2007 08:51 AM
Phil75
Mar 3, 2003 03:16 PM
